Sgimpi
Like Tree1Likes
Old   June 23, 2011, 06:11
Default Sgimpi
pere
pere is on a distinguished road
I have compiled OpenFOAM 1.7.1 for openmpi and I need to use it with sgimpi. How can I do it? I've changed $WM_MPLIB and $WM_PROJECT_DIR/wmake/rules/linuxIA64Icc/mpilibSGIMPI where I've made
PFLAGS = -DOMPI_SKIP_MPICXX
PINC = -I/opt/sgi/mpt/mpt-2.03/include
PLIBS = -L/opt/sgi/mpt/mpt-2.03/lib -lmpi
and after ./Allmake at WM_PROJECT_DIR
Is this right?
pere is offline   Reply With Quote
Old   June 25, 2011, 07:47
Retired Super Moderator
Bruno Santos
Hi Pere,
Yeah, that should be pretty much it. I'm not sure if there is anything else missing for building with SGI-MPI.
No, wait, have you checked "OpenFOAM-1.7.1/etc/settings.sh"?
There might be some issues with Metis and Scotch if you have previously built on the same machine with OpenMPI. So you might need to either run Allwmake twice or play it safe and rebuild the whole thing again with the new options.
Best regards,
Bruno
Old   June 30, 2011, 06:32
pere
Hi Bruno,
Yes, I've checked settings.sh and I added:
SGIMPI)
export MPI_ARCH_PATH=/prod/OPENFOAM1.7.1/OPENFOAM-1.7.1-SGI/OPENFOAM-1.7.1/mpt-2.03
# Tell OpenMPI where to find its install directory
export OPAL_PREFIX=$MPI_ARCH_PATH
_foamAddPath $MPI_ARCH_PATH/bin
_foamAddLib $MPI_ARCH_PATH/lib
_foamAddMan $MPI_ARCH_PATH/man
export FOAM_MPI_LIBBIN=/prod/OPENFOAM1.7.1/OPENFOAM-1.7.1-SGI/OPENFOAM-1.7.1/mpt-2.03/lib
but when Itry to execute OpenFOAM this message appairs:
Warning: Command line arguments for program should be given
after the program name. Assuming that -parallel is a
command line argument for the program.
Missing: program name
Program buoyantBoussinesqPimpleFoam either does not exist, is not
executable, or is an erroneous argument to mpirun.
Does not detect correctly mpirun....
Does anyone knows where is the problem?
Old   June 30, 2011, 06:59
akidess's Avatar
Anton Kidess
Does buoyantBoussinesqPimpleFoam run in serial? Did you try giving mpirun the complete path (i.e. ~/OpenFOAM/USER-V.x/applications/bin/linux64GccDPOpt/buoyantBoussinesqPimpleFoam)?
Old   June 30, 2011, 17:52
Bruno Santos
Hi Pere and Anton,
@Pere:
Right now I don't have time to go into details, so I'll simply copy-paste the links I've got on one of my blog posts:
Originally Posted by http://www.cfd-online.com/Forums/blogs/wyldckat/232-list-threads-useful-building-openfoam-other-third-party-tools.html
Basically, there are 2 details to keep in mind:
  • Whenever possible, use full paths to mpirun and foamExec. foamExec will activate OpenFOAM's environment on the remote shells launched by mpirun.
  • Or, if you want to use mpirun straight up, you must use the normal method for activating OpenFOAM's environment, namely:
    Originally Posted by http://www.openfoam.com/download/source.php#x5-22000
    if running bash or ksh (if in doubt type echo $SHELL), source the etc/bashrc file by adding the following line to the end of your $HOME/.bashrc file:
    source $HOME/OpenFOAM/OpenFOAM-2.0.0/etc/bashrc
If you still can't get it to work after checking those links I posted above, this weekend I can give a more detailed guide line
Best regards and good luck!
Bruno
Old   July 1, 2011, 03:32
pere
Yes I tried the full path and the same error appears...
Old   July 2, 2011, 04:49
Bruno Santos
Hi Pere,
I'm sorry, but this is too little information I'm unable to deduce whether it's an environment problem or if something is missing when you run mpirun.
So, here's a list of things I'll need to know:
  1. What is the whole complete command line you are using for launching the solver buoyantBoussinesqPimpleFoam?
  2. Are you trying to use just the local machine or multiple machines?
  3. If you are using multiple machines:
    1. Is OpenFOAM installed in all of them in the exact same place?
    2. Is it shared via NFS or some other network file sharing mechanism?
As an example, I'll use the tutorial "heatTransfer/buoyantBoussinesqSimpleFoam/iglooWithFridges" with the full command lines for running in parallel in the local host:
mkdir -p $FOAM_RUN
run
cp -r $FOAM_TUTORIALS .
cd tutorials/heatTransfer/buoyantBoussinesqSimpleFoam/iglooWithFridges
blockMesh
snappyHexMesh -overwrite
decomposePar
`which mpirun` -np 6 /home/myusername/OpenFOAM/OpenFOAM-1.7.1/bin/foamExec buoyantBoussinesqSimpleFoam -parallel
Also, run this command to confirm it's picking up on the correct mpirun binary:
echo `which mpirun`
Best regards,
Bruno
Old   July 4, 2011, 04:40
pere
I've solucionazied the first error and now I had this problem:
PI: pirineus: 0x9d400004db86f34:
MPI: pirineus: 0x9d400004db86f34:
MPI: pirineus: 0x9d400004db86f34: --> FOAM FATAL ERROR:
MPI: pirineus: 0x9d400004db86f34: Trying to use the dummy Pstream library.
MPI: pirineus: 0x9d400004db86f34: This dummy library cannot be used in parallel mode
MPI: pirineus: 0x9d400004db86f34: From function Pstream::init(int& argc, char**& argv)
MPI: pirineus: 0x9d400004db86f34: in file Pstream.C at line 39.
MPI: pirineus: 0x9d400004db86f34: FOAM exiting
MPI: could not run executable (case #4)
Did I have to modify Pstream.C?
Old   July 4, 2011, 19:40
Bruno Santos
Noooo, go back!! The dummy library only exists for OpenFOAM builds that run only in single-core-single-machine set-ups!
Changing the Pstream code is only necessary in very specific situations, namely for MPI libraries that use non-conventional ways of doing MPI business. This would usually only be the case for older MPI libraries and some closed source ones, such for Cray super-computers (I'm just guessing on this last one).
Old   July 5, 2011, 03:11
pere
Thanks wyldckat. So what do you think I must do now?
Old   July 5, 2011, 06:40
pere
I've changed Allwmake in Pstream and I put wmake libso mpi instead of wmake libso dummy, after ..../Pstream>./Allwmake....but the error is the same again...
Old   July 6, 2011, 19:36
Bruno Santos
Hi Pere,
I didn't have time to respond sooner... anyway, it's time for some divide and conquer:
  1. Run mpirun with a test for launching mpi'less applications. For example, run each one of these at a time:
    mpirun -np 2 bash -c "ls -l"
    mpirun -np 2 bash -c "export"
    The first one will show you the contents of the folder each remotely launched bash shell. The second one will show you the environment variables for each remote shell.
    If neither one of these work, then your MPI installation isn't working.
  2. Build the test application designed for these kinds of tests:
    cd $WM_PROJECT_DIR
    wmake applications/test/parallel
    Now go to your case that has the decomposePar already done.
    Then run the following scenarios:
    1. Test to see what the new application shows:
      parallelTest
    2. Testing if the OpenFOAM environment is available in the remote shells:
      mpirun -np 2 parallelTest
      It should show you the result of the 1st test of this sub-list, but twice.
    3. Testing if foamExec does his job:
      mpirun -np 2 `which foamExec` parallelTest
    4. Testing if you can run things in parallel:
      mpirun -np 2 parallelTest -parallel
      In this case, it should show you a similar output to what's shown here: post #19 of "OpenFOAM updates"
    5. Finally, test if foamJob works:
      foamJob -s -p parallelTest
These tests should help you isolate the problem.
Bruno
sunshuai likes this.
Old   July 8, 2011, 04:08
pere
I cannot build parallelTest, this error appears:
SOURCE=parallelTest.C ; g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-40 -IlnInclude -I. -I/prod/OPENFOAM1.7.1/OpenFOAM-1.7.1-SGI/OpenFOAM-1.7.1/src/OpenFOAM/lnInclude -I/prod/OPENFOAM1.7.1/OpenFOAM-1.7.1-SGI/OpenFOAM-1.7.1/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linux64GccDPOpt/parallelTest.o
In file included from /prod/OPENFOAM1.7.1/ThirdParty-1.7.1/gcc-4.5.2/bin/../lib/gcc/x86_64-unknown-linux-gnu/4.5.2/../../../../include/c++/4.5.2/bits/localefwd.h:42:0,
from /prod/OPENFOAM1.7.1/ThirdParty-1.7.1/gcc-4.5.2/bin/../lib/gcc/x86_64-unknown-linux-gnu/4.5.2/../../../../include/c++/4.5.2/string:45,
from /prod/OPENFOAM1.7.1/OpenFOAM-1.7.1-SGI/OpenFOAM-1.7.1/src/OpenFOAM/lnInclude/string.H:51,
from /prod/OPENFOAM1.7.1/OpenFOAM-1.7.1-SGI/OpenFOAM-1.7.1/src/OpenFOAM/lnInclude/stringList.H:35,
from /prod/OPENFOAM1.7.1/OpenFOAM-1.7.1-SGI/OpenFOAM-1.7.1/src/OpenFOAM/lnInclude/argList.H:73,
from parallelTest.C:32:
/prod/OPENFOAM1.7.1/ThirdParty-1.7.1/gcc-4.5.2/bin/../lib/gcc/x86_64-unknown-linux-gnu/4.5.2/../../../../include/c++/4.5.2/x86_64-unknown-linux-gnu/bits/c++locale.h:52:23: error: ‘uselocale’ was not declared in this scope
/prod/OPENFOAM1.7.1/ThirdParty-1.7.1/gcc-4.5.2/bin/../lib/gcc/x86_64-unknown-linux-gnu/4.5.2/../../../../include/c++/4.5.2/x86_64-unknown-linux-gnu/bits/c++locale.h:52:45: error: invalid type in declaration before ‘;’ token
/prod/OPENFOAM1.7.1/ThirdParty-1.7.1/gcc-4.5.2/bin/../lib/gcc/x86_64-unknown-linux-gnu/4.5.2/../../../../include/c++/4.5.2/x86_64-unknown-linux-gnu/bits/c++locale.h: In function ‘int std::__convert_from_v(__locale_struct* const&, char*, int, const char*, ...)’:
/prod/OPENFOAM1.7.1/ThirdParty-1.7.1/gcc-4.5.2/bin/../lib/gcc/x86_64-unknown-linux-gnu/4.5.2/../../../../include/c++/4.5.2/x86_64-unknown-linux-gnu/bits/c++locale.h:72:53: error: ‘__gnu_cxx::__uselocale’ cannot be used as a function
/prod/OPENFOAM1.7.1/ThirdParty-1.7.1/gcc-4.5.2/bin/../lib/gcc/x86_64-unknown-linux-gnu/4.5.2/../../../../include/c++/4.5.2/x86_64-unknown-linux-gnu/bits/c++locale.h:97:33: error: ‘__gnu_cxx::__uselocale’ cannot be used as a function
make: *** [Make/linux64GccDPOpt/parallelTest.o] Error 1
Is it possible that I need new headers? libraries?
The real problem is that OpenFOAM needs Pstream/mpi instead of Pstream/dummy from running ni parallel?
Thanks in advance wlydcat
Old   July 8, 2011, 06:49
pere
Ok finally I can start parallelTest....
Old   July 8, 2011, 07:01
pere
when I made parallelTest:
| \\ / O peration | Version: 1.7.1 |
| \\ / A nd | Web: www.OpenFOAM.com |
| \\/ M anipulation | |
Build : 1.7.1-03e7e056c215
Exec : parallelTest
Date : Jul 08 2011
Time : 12:47:19
Host : pirineus
PID : 340804
Case : /tmp/ppuigdom/snappy24_2/snappy24
nProcs : 1
SigFpe : Enabling floating point exception trapping (FOAM_SIGFPE).
Create time
Starting transfers
End
-mpirun -np 2 parallelTest
Exec : parallelTest
Date : Jul 08 2011
Time : 12:50:25
Host : pirineus
PID : 341946
nProcs : 1
Create time
End
MPI: pirineus: 0x9d400004db8713b:
MPI: pirineus: 0x9d400004db8713b: Starting transfers
-mpirun -np 2 which foamExec parallelTest
/prod/OPENFOAM1.7.1/OpenFOAM-1.7.1-SGI/OpenFOAM-1.7.1/bin/foamExec
/home/ppuigdom/OpenFOAM/ppuigdom-1.7.1/applications/bin/linux64GccDPOpt/parallelTest
MPI: could not run executable (case #3)
MPI: No details available, no log files found
-mpirun -np 2 parallelTest -parallel
MPI: pirineus: 0x9d400004db87141:
MPI: pirineus: 0x9d400004db87141: --> FOAM FATAL ERROR:
MPI: pirineus: 0x9d400004db87141: Trying to use the dummy Pstream library.
MPI: pirineus: 0x9d400004db87141: This dummy library cannot be used in parallel mode
MPI: pirineus: 0x9d400004db87141: From function Pstream::init(int& argc, char**& argv)
MPI: pirineus: 0x9d400004db87141: in file Pstream.C at line 39.
MPI: pirineus: 0x9d400004db87141: FOAM exiting
-foamJob -p -s parallelTest
Parallel processing using SGIMPI with 10 processors
Executing: mpirun -np 10 /prod/OPENFOAM1.7.1/OpenFOAM-1.7.1-SGI/OpenFOAM-1.7.1/bin/foamExec parallelTest -parallel | tee log
MPI: pirineus: 0x9d400004db87144:
MPI: pirineus: 0x9d400004db87144: --> FOAM FATAL ERROR:
MPI: pirineus: 0x9d400004db87144: Trying to use the dummy Pstream library.
MPI: pirineus: 0x9d400004db87144: This dummy library cannot be used in parallel mode
MPI: pirineus: 0x9d400004db87144: From function Pstream::init(int& argc, char**& argv)
MPI: pirineus: 0x9d400004db87144: in file Pstream.C at line 39.
MPI: pirineus: 0x9d400004db87144: FOAM exiting
Is the problem dummy library? how can I change it for mpi library?
Thanks
Old   July 9, 2011, 04:57
Bruno Santos
Hi Pere,
Just the other day I had to suggest to another person to do the following instruction:
mv $FOAM_LIBBIN/dummy $FOAM_LIBBIN/dummy__
Basically, rename/hide the dummy folder, which is where the libraries for MPI'less operation are.
Then try again.
By the way, you didn't mention if the first two commands had worked or not. I suppose they did and that's why you went ahead to test parallelTest.
Best regards,
Bruno
Old   July 11, 2011, 04:19
pere
total 12
drwxr-x--- 2 ppuigdom cesca 4096 16 jun 11:17 0
drwxr-x--- 4 ppuigdom cesca 4096 16 jun 11:17 constant
-rw-r----- 1 ppuigdom cesca 0 11 jul 09:49 log
drwxr-x--- 4 ppuigdom cesca 41 4 jul 10:21 processor0
drwxr-x--- 4 ppuigdom cesca 41 4 jul 10:22 processor1
drwxr-x--- 4 ppuigdom cesca 41 4 jul 10:22 processor2
drwxr-x--- 4 ppuigdom cesca 41 4 jul 10:22 processor3
drwxr-x--- 4 ppuigdom cesca 41 4 jul 10:22 processor4
drwxr-x--- 4 ppuigdom cesca 41 4 jul 10:22 processor5
drwxr-x--- 4 ppuigdom cesca 41 4 jul 10:22 processor6
drwxr-x--- 4 ppuigdom cesca 41 4 jul 10:22 processor7
drwxr-x--- 4 ppuigdom cesca 41 4 jul 10:22 processor8
drwxr-x--- 4 ppuigdom cesca 41 4 jul 10:22 processor9
drwxr-x--- 2 ppuigdom cesca 4096 16 jun 11:17 system
Matat
declare -x AWK="gawk"
declare -x BASH_ENV="/home/ppuigdom/.bashrc"
declare -x BINARY_TYPE="linux2.6-glibc2.3-x86_64"
declare -x BINARY_TYPE_HPC=""
declare -x BSUB_BLOCK_EXEC_HOST=""
declare -x COLORTERM="1"
declare -x CPATH="/prod/intel/Compiler/11.1/073/ipp/em64t/include:/prod/intel/Compiler/11.1/073/mkl/include:/prod/intel/Compiler/11.1/073/tbb/include:/prod/intel/Compiler/11.1/073/ipp/em64t/include:/prod/intel/Compiler/11.1/073/mkl/include:/prod/intel/Compiler/11.1/073/tbb/include"
declare -x CPU="x86_64"
declare -x CSHEDIT="emacs"
declare -x CVS_RSH="ssh"
declare -x DADES="/dades/ppuigdom"
declare -x DISPLAY="localhost:18.0"
declare -x DYLD_LIBRARY_PATH="/prod/intel/Compiler/11.1/073/tbb/intel64/cc4.1.0_libc2.4_kernel2.6.16.21/lib:/prod/intel/Compiler/11.1/073/tbb/intel64/cc4.1.0_libc2.4_kernel2.6.16.21/lib"
declare -x EGO_BINDIR="/usr/share/lsf/7.0/linux2.6-glibc2.3-x86_64/bin"
declare -x EGO_CONFDIR="/usr/share/lsf/conf/ego/CESCA/kernel"
declare -x EGO_ESRVDIR="/usr/share/lsf/conf/ego/CESCA/eservice"
declare -x EGO_LIBDIR="/usr/share/lsf/7.0/linux2.6-glibc2.3-x86_64/lib"
declare -x EGO_LOCAL_CONFDIR="/usr/share/lsf/conf/ego/CESCA/kernel"
declare -x EGO_SERVERDIR="/usr/share/lsf/7.0/linux2.6-glibc2.3-x86_64/etc"
declare -x EGO_TOP="/usr/share/lsf"
declare -x EGO_VERSION="1.2"
declare -x ENV="/etc/bash.bashrc"
declare -x FOAM_APP="/prod/OPENFOAM1.7.1/OpenFOAM-1.7.1-SGI/OpenFOAM-1.7.1/applications"
declare -x FOAM_APPBIN="/prod/OPENFOAM1.7.1/OpenFOAM-1.7.1-SGI/OpenFOAM-1.7.1/applications/bin/linux64GccDPOpt"
declare -x FOAM_INST_DIR="/prod/OPENFOAM1.7.1/OpenFOAM-1.7.1-SGI"
declare -x FOAM_JOB_DIR="/prod/OPENFOAM1.7.1/OpenFOAM-1.7.1-SGI/jobControl"
declare -x FOAM_LIB="/prod/OPENFOAM1.7.1/OpenFOAM-1.7.1-SGI/OpenFOAM-1.7.1/lib"
declare -x FOAM_LIBBIN="/prod/OPENFOAM1.7.1/OpenFOAM-1.7.1-SGI/OpenFOAM-1.7.1/lib/linux64GccDPOpt"
declare -x FOAM_MPI_LIBBIN="/prod/OPENFOAM1.7.1/OpenFOAM-1.7.1-SGI/OpenFOAM-1.7.1/mpt-2.03/lib"
declare -x FOAM_RUN="/home/ppuigdom/OpenFOAM/ppuigdom-1.7.1/run"
declare -x FOAM_SIGFPE=""
declare -x FOAM_SITE_APPBIN="/prod/OPENFOAM1.7.1/OpenFOAM-1.7.1-SGI/site/1.7.1/bin/linux64GccDPOpt"
declare -x FOAM_SITE_LIBBIN="/prod/OPENFOAM1.7.1/OpenFOAM-1.7.1-SGI/site/1.7.1/lib/linux64GccDPOpt"
declare -x FOAM_SOLVERS="/prod/OPENFOAM1.7.1/OpenFOAM-1.7.1-SGI/OpenFOAM-1.7.1/applications/solvers"
declare -x FOAM_SRC="/prod/OPENFOAM1.7.1/OpenFOAM-1.7.1-SGI/OpenFOAM-1.7.1/src"
declare -x FOAM_TUTORIALS="/prod/OPENFOAM1.7.1/OpenFOAM-1.7.1-SGI/OpenFOAM-1.7.1/tutorials"
declare -x FOAM_USER_APPBIN="/home/ppuigdom/OpenFOAM/ppuigdom-1.7.1/applications/bin/linux64GccDPOpt"
declare -x FOAM_USER_LIBBIN="/home/ppuigdom/OpenFOAM/ppuigdom-1.7.1/lib/linux64GccDPOpt"
declare -x FOAM_UTILITIES="/prod/OPENFOAM1.7.1/OpenFOAM-1.7.1-SGI/OpenFOAM-1.7.1/applications/utilities"
declare -x FPATH="/prod/intel/Compiler/11.1/073/mkl/include:/prod/intel/Compiler/11.1/073/mkl/include"
declare -x FROM_HEADER=""
declare -x G_BROKEN_FILENAMES="1"
declare -x G_FILENAME_ENCODING="@locale,UTF-8,ISO-8859-15,CP1252"
declare -x HISTSIZE="1000"
declare -x HOME="/home/ppuigdom"
declare -x HOST="pirineus"
declare -x HOSTNAME="pirineus"
declare -x HOSTTYPE="X86_64"
declare -x INCLUDE="/prod/intel/Compiler/11.1/073/ipp/em64t/include:/prod/intel/Compiler/11.1/073/mkl/include:/prod/intel/Compiler/11.1/073/ipp/em64t/include:/prod/intel/Compiler/11.1/073/mkl/include"
declare -x INFODIR="/usr/local/info:/usr/share/info:/usr/info"
declare -x INFOPATH="/usr/local/info:/usr/share/info:/usr/info"
declare -x INPUTRC="/etc/inputrc"
declare -x INTEL_LICENSE_FILE="/prod/intel/Compiler/11.1/073/licenses:/opt/intel/licenses:/home/ppuigdom/intel/licenses:/prod/intel/Compiler/11.1/073/licenses:/opt/intel/licenses:/home/ppuigdom/intel/licenses"
declare -x IPPROOT="/prod/intel/Compiler/11.1/073/ipp/em64t"
declare -x JAVA_BINDIR="/usr/lib64/jvm/jre/bin"
declare -x JAVA_HOME="/usr/share/lsf/perf/../jre/linux-x86_64"
declare -x JAVA_ROOT="/usr/lib64/jvm/jre"
declare -x JRE_HOME="/usr/lib64/jvm/jre"
declare -x KMP_AFFINITY="disable"
declare -x LANG="ca_ES.UTF-8"
declare -x LD_LIBRARY_PATH="/prod/OPENFOAM1.7.1/ThirdParty-1.7.1/platforms/linux64Gcc/paraview-3.8.0/lib/paraview-3.8:/prod/OPENFOAM1.7.1/OpenFOAM-1.7.1-SGI/OpenFOAM-1.7.1/mpt-2.03/lib:/usr/lib64/gcc/x86_64-suse-linux/4.3:/home/ppuigdom/OpenFOAM/ppuigdom-1.7.1/lib/linux64GccDPOpt:/prod/OPENFOAM1.7.1/OpenFOAM-1.7.1-SGI/site/1.7.1/lib/linux64GccDPOpt:/prod/OPENFOAM1.7.1/OpenFOAM-1.7.1-SGI/OpenFOAM-1.7.1/lib/linux64GccDPOpt:/prod/OPENFOAM1.7.1/OpenFOAM-1.7.1-SGI/OpenFOAM-1.7.1/lib/linux64GccDPOpt/dummy:/usr/share/lsf/7.0/linux2.6-glibc2.3-x86_64/lib:/usr/lib64/jvm/jre-1.6.0-sun/lib/amd64/server:/usr/lib64/jvm/jre-1.6.0-sun/lib/amd64:/usr/share/lsf/perf/1.2/linux-x86_64/lib:/usr/share/lsf/perf/ego/1.2/linux-x86_64/lib:/usr/share/lsf/perf/lsf/7.0/linux-x86_64/lib:/usr/share/lsf/1.2/linux2.6-glibc2.3-x86_64/lib:/prod/intel/Compiler/11.1/073/lib/intel64:/prod/intel/Compiler/11.1/073/ipp/em64t/sharedlib:/prod/intel/Compiler/11.1/073/mkl/lib/em64t:/prod/intel/Compiler/11.1/073/tbb/intel64/cc4.1.0_libc2.4_kernel2.6.16.21/lib:/opt/sgi/sgimc/lib"
declare -x LD_PRELOAD="libxpmem.so"
declare -x LESS="-M -I"
declare -x LESSCLOSE="lessclose.sh %s %s"
declare -x LESSKEY="/etc/lesskey.bin"
declare -x LESSOPEN="lessopen.sh %s"
declare -x LESS_ADVANCED_PREPROCESSOR="no"
declare -x LIB="/prod/intel/Compiler/11.1/073/ipp/em64t/lib:/prod/intel/Compiler/11.1/073/ipp/em64t/lib:"
declare -x LIBRARY_PATH="/prod/intel/Compiler/11.1/073/lib/intel64:/prod/intel/Compiler/11.1/073/ipp/em64t/lib:/prod/intel/Compiler/11.1/073/mkl/lib/em64t:/prod/intel/Compiler/11.1/073/tbb/intel64/cc4.1.0_libc2.4_kernel2.6.16.21/lib:/prod/intel/Compiler/11.1/073/lib/intel64:/prod/intel/Compiler/11.1/073/ipp/em64t/lib:/prod/intel/Compiler/11.1/073/mkl/lib/em64t:/prod/intel/Compiler/11.1/073/tbb/intel64/cc4.1.0_libc2.4_kernel2.6.16.21/lib"
declare -x LICENSE_FILE="/usr/share/lsf/conf/perf/CESCA/conf/license.dat"
declare -x LM_LICENSE_FILE="27000@192.168.17.1"
declare -x LOADEDMODULES=""
declare -x LOGNAME="ppuigdom"
declare -x LSB_ACCT_FILE="/tmp/ppuigdom/.1310369970.702642.acct"
declare -x LSB_BATCH_JID="702642"
declare -x LSB_CHKFILENAME="/home/ppuigdom/.lsbatch/1310369970.702642"
declare -x LSB_CPUSET_DEDICATED="YES"
declare -x LSB_DJOB_HB_INTERVAL="15"
declare -x LSB_DJOB_HOSTFILE="/home/ppuigdom/.lsbatch/1310369970.702642.hostfile"
declare -x LSB_DJOB_NUMPROC="1"
declare -x LSB_DJOB_RU_INTERVAL="15"
declare -x LSB_ECHKPNT_RSH_CMD="ssh -p2122"
declare -x LSB_EEXEC_REAL_GID=""
declare -x LSB_EEXEC_REAL_UID=""
declare -x LSB_EXEC_CLUSTER="CESCA"
declare -x LSB_EXIT_PRE_ABORT="99"
declare -x LSB_HOSTS="pirineus"
declare -x LSB_HOST_CPUSETS="1 pirineus /CESCA@702642 "
declare -x LSB_INTERACTIVE="Y"
declare -x LSB_JOBEXIT_STAT="0"
declare -x LSB_JOBFILENAME="/home/ppuigdom/.lsbatch/1310369970.702642"
declare -x LSB_JOBID="702642"
declare -x LSB_JOBINDEX="0"
declare -x LSB_JOBNAME="/bin/bash"
declare -x LSB_JOBRES_CALLBACK="52029@pirineus"
declare -x LSB_JOBRES_PID="756365"
declare -x LSB_JOB_EXECUSER="ppuigdom"
declare -x LSB_JOB_STARTER="/usr/local/bin/lsf_job_starter"
declare -x LSB_MCPU_HOSTS="pirineus 1 "
declare -x LSB_QUEUE="short"
declare -x LSB_SHMODE="y"
declare -x LSB_SUB_HOST="pirineus"
declare -x LSB_TRAPSIGS="trap # 15 10 12 2 1"
declare -x LSB_UNIXGROUP_INT="cesca"
declare -x LSB_XFJOB="Y"
declare -x LSFUSER="ppuigdom"
declare -x LSF_BINDIR="/usr/share/lsf/7.0/linux2.6-glibc2.3-x86_64/bin"
declare -x LSF_EAUTH_AUX_PASS="yes"
declare -x LSF_EAUTH_CLIENT="user"
declare -x LSF_EAUTH_SERVER="mbatchd@CESCA"
declare -x LSF_EGO_ENVDIR="/usr/share/lsf/conf/ego/CESCA/kernel"
declare -x LSF_ENVDIR="/usr/share/lsf/conf"
declare -x LSF_INVOKE_CMD="bsub.lsf"
declare -x LSF_LIBDIR="/usr/share/lsf/7.0/linux2.6-glibc2.3-x86_64/lib"
declare -x LSF_LIM_API_NTRIES="1"
declare -x LSF_LOGDIR="/usr/share/lsf/log"
declare -x LSF_SERVERDIR="/usr/share/lsf/7.0/linux2.6-glibc2.3-x86_64/etc"
declare -x LSF_VERSION="23"
declare -x LS_COLORS="no=00:fi=00:di=01;34:ln=00;36i=40;33: so=01;35:do=01;35:bd=40;33;01:cd=40;33;01r=41;33 ;01:ex=00;32:*.cmd=00;32:*.exe=01;32:*.com=01;32:* .bat=01;32:*.btm=01;32:*.dll=01;32:*.tar=00;31:*.t bz=00;31:*.tgz=00;31:*.rpm=00;31:*.deb=00;31:*.arj =00;31:*.taz=00;31:*.lzh=00;31:*.lzma=00;31:*.zip= 00;31:*.zoo=00;31:*.z=00;31:*.Z=00;31:*.gz=00;31:* .bz2=00;31:*.tb2=00;31:*.tz2=00;31:*.tbz2=00;31:*. avi=01;35:*.bmp=01;35:*.fli=01;35:*.gif=01;35:*.jp g=01;35:*.jpeg=01;35:*.mng=01;35:*.mov=01;35:*.mpg =01;35:*.pcx=01;35:*.pbm=01;35:*.pgm=01;35:*.png=0 1;35:*.ppm=01;35:*.tga=01;35:*.tif=01;35:*.xbm=01; 35:*.xpm=01;35:*.dl=01;35:*.gl=01;35:*.wmv=01;35:* .aiff=00;32:*.au=00;32:*.mid=00;32:*.mp3=00;32:*.o gg=00;32:*.voc=00;32:*.wav=00;32:"
declare -x LS_EXEC_T="START"
declare -x LS_JOBPID="756365"
declare -x LS_OPTIONS="-N --color=tty -T 0"
declare -x LS_SUBCWD="/tmp/ppuigdom/snappy24_2/snappy24"
declare -x MACHTYPE="x86_64-suse-linux"
declare -x MAIL="/var/mail/ppuigdom"
declare -x MANPATH="/prod/OPENFOAM1.7.1/OpenFOAM-1.7.1-SGI/OpenFOAM-1.7.1/mpt-2.03/man:/usr/share/lsf/7.0/man:/prod/intel/Compiler/11.1/073/man/en_US:/prod/intel/Compiler/11.1/073/mkl/man/en_US:/prod/intel/Compiler/11.1/073/mkl/../man/en_US:/prod/intel/Compiler/11.1/073/mkl/man/en_US:/usr/local/man:/usr/share/man:/prod/intel/vtune/man:"
declare -x MAQUINA="pirineus"
declare -x MGR_HOME="/opt/sgi/sgimc"
declare -x MINICOM="-c on"
declare -x MKLROOT="/prod/intel/Compiler/11.1/073/mkl"
declare -x MODULEPATH="/opt/modules/tools:/opt/modules/modulefiles"
declare -x MODULESHOME="/usr/share/modules"
declare -x MODULE_VERSION="3.1.6"
declare -x MODULE_VERSION_STACK="3.1.6"
declare -x MORE="-sl"
declare -x MPI_ARCH_PATH="/prod/OPENFOAM1.7.1/OpenFOAM-1.7.1-SGI/OpenFOAM-1.7.1/mpt-2.03"
declare -x MPI_BUFFER_SIZE="20000000"
declare -x MPI_DRANK="0"
declare -x MPI_ENVIRONMENT="6a085854 38938 0 e007c336 9d400004db871d1"
declare -x MPI_IDB_PATH="/prod/intel/Compiler/11.1/073/bin/intel64/idb"
declare -x MPI_SHARED_NEIGHBORHOOD="host"
declare -x NLSPATH="/prod/intel/Compiler/11.1/073/lib/intel64/locale/%l_%t/%N:/prod/intel/Compiler/11.1/073/ipp/em64t/lib/locale/%l_%t/%N:/prod/intel/Compiler/11.1/073/mkl/lib/em64t/locale/%l_%t/%N:/prod/intel/Compiler/11.1/073/idb/intel64/locale/%l_%t/%N:/prod/intel/Compiler/11.1/073/lib/intel64/locale/%l_%t/%N:/prod/intel/Compiler/11.1/073/ipp/em64t/lib/locale/%l_%t/%N:/prod/intel/Compiler/11.1/073/mkl/lib/em64t/locale/%l_%t/%N:/prod/intel/Compiler/11.1/073/idb/intel64/locale/%l_%t/%N"
declare -x NNTPSERVER="news"
declare -x OLDPWD
declare -x OPAL_PREFIX="/prod/OPENFOAM1.7.1/OpenFOAM-1.7.1-SGI/OpenFOAM-1.7.1/mpt-2.03"
declare -x OSTYPE="linux"
declare -x OS_TYPE="linux-x86_64"
declare -x PAGER="less"
declare -x PAMENV="/prod/ESI-SW/visualenv66/env-Linux"
declare -x PAMHOME="/prod/ESI-SW/visualenv66"
declare -x PAMLANG="FR"
declare -x PATH="/prod/OPENFOAM1.7.1/ThirdParty-1.7.1/platforms/linux64Gcc/paraview-3.8.0/bin:/prod/OPENFOAM1.7.1/OpenFOAM-1.7.1-SGI/OpenFOAM-1.7.1/mpt-2.03/bin:/usr/bin/gcc:/home/ppuigdom/OpenFOAM/ppuigdom-1.7.1/applications/bin/linux64GccDPOpt:/prod/OPENFOAM1.7.1/OpenFOAM-1.7.1-SGI/site/1.7.1/bin/linux64GccDPOpt:/prod/OPENFOAM1.7.1/OpenFOAM-1.7.1-SGI/OpenFOAM-1.7.1/applications/bin/linux64GccDPOpt:/prod/OPENFOAM1.7.1/OpenFOAM-1.7.1-SGI/OpenFOAM-1.7.1/wmake:/prod/OPENFOAM1.7.1/OpenFOAM-1.7.1-SGI/OpenFOAM-1.7.1/bin:/usr/share/lsf/7.0/linux2.6-glibc2.3-x86_64/bin:/prod/pgi/linux86-64/10.5/bin:/usr/share/lsf/gui/2.0/bin:/usr/share/lsf/perf/1.2/bin:/usr/share/lsf/7.0/linux2.6-glibc2.3-x86_64/etc:/prod/intel/Compiler/11.1/073/bin/intel64:/usr/local/bin:/usr/bin:/bin:/usr/bin/X11:/usr/X11R6/bin:/usr/games:/usr/lib64/jvm/jre/bin:/usr/lib/mit/bin:/usr/lib/mit/sbin:/opt/sgi/sgimc/bin:/opt/sgi/sbin"
declare -x PERF_CONFDIR="/usr/share/lsf/conf/perf/CESCA/conf"
declare -x PERF_DATADIR="/usr/share/lsf/work/CESCA/perf/data"
declare -x PERF_ENV="-DPERF_TOP=/usr/share/lsf/perf -DPERF_CONFDIR=/usr/share/lsf/conf/perf/CESCA/conf -DPERF_WORKDIR=/usr/share/lsf/work/CESCA/perf -DPERF_LOGDIR=/usr/share/lsf/log/perf -DPERF_DATADIR=/usr/share/lsf/work/CESCA/perf/data"
declare -x PERF_LIB="/usr/share/lsf/perf/1.2/linux-x86_64/lib:/usr/share/lsf/perf/ego/1.2/linux-x86_64/lib:/usr/share/lsf/perf/lsf/7.0/linux-x86_64/lib"
declare -x PERF_LIB_TYPE="linux-x86_64"
declare -x PERF_LOGDIR="/usr/share/lsf/log/perf"
declare -x PERF_TOP="/usr/share/lsf/perf"
declare -x PERF_VERSION="1.2"
declare -x PERF_WORKDIR="/usr/share/lsf/work/CESCA/perf"
declare -x PGI="/prod/pgi"
declare -x PROFILEREAD="true"
declare -x PV_PLUGIN_PATH="/prod/OPENFOAM1.7.1/OpenFOAM-1.7.1-SGI/OpenFOAM-1.7.1/lib/linux64GccDPOpt/paraview-3.8"
declare -x PWD="/tmp/ppuigdom/snappy24_2/snappy24"
declare -x PYTHONSTARTUP="/etc/pythonstart"
declare -x ParaView_DIR="/prod/OPENFOAM1.7.1/ThirdParty-1.7.1/platforms/linux64Gcc/paraview-3.8.0"
declare -x ParaView_MAJOR="3.8"
declare -x ParaView_VERSION="3.8.0"
declare -x QT_SYSTEM_DIR="/usr/share/desktop-data"
declare -x SBD_KRB5CCNAME_VAL=""
declare -x SCRATCH="/cescascratch/ppuigdom"
declare -x SHELL="/usr/local/bin/bash"
declare -x SHLVL="7"
declare -x SSH_CLIENT="192.94.163.141 57706 2122"
declare -x SSH_CONNECTION="192.94.163.141 57706 84.88.8.106 2122"
declare -x SSH_SENDS_LOCALE="yes"
declare -x SSH_TTY="/dev/pts/28"
declare -x TERM="xterm"
declare -x TMOUT="10800"
declare -x TMPDIR="/tmp/ppuigdom/702642.201107110949"
declare -x USER="ppuigdom"
declare -x WINDOWMANAGER="/usr/bin/gnome"
declare -x WM_ARCH="linux64"
declare -x WM_ARCH_OPTION="64"
declare -x WM_CC="gcc"
declare -x WM_CFLAGS="-m64 -fPIC"
declare -x WM_COMPILER="Gcc"
declare -x WM_COMPILER_LIB_ARCH="64"
declare -x WM_COMPILE_OPTION="Opt"
declare -x WM_CXX="g++"
declare -x WM_CXXFLAGS="-m64 -fPIC"
declare -x WM_DIR="/prod/OPENFOAM1.7.1/OpenFOAM-1.7.1-SGI/OpenFOAM-1.7.1/wmake"
declare -x WM_LDFLAGS="-m64"
declare -x WM_LINK_LANGUAGE="c++"
declare -x WM_MPLIB="SGIMPI"
declare -x WM_OPTIONS="linux64GccDPOpt"
declare -x WM_OSTYPE="POSIX"
declare -x WM_PRECISION_OPTION="DP"
declare -x WM_PROJECT="OpenFOAM"
declare -x WM_PROJECT_DIR="/prod/OPENFOAM1.7.1/OpenFOAM-1.7.1-SGI/OpenFOAM-1.7.1"
declare -x WM_PROJECT_INST_DIR="/prod/OPENFOAM1.7.1/OpenFOAM-1.7.1-SGI"
declare -x WM_PROJECT_USER_DIR="/home/ppuigdom/OpenFOAM/ppuigdom-1.7.1"
declare -x WM_PROJECT_VERSION="1.7.1"
declare -x WM_THIRD_PARTY_DIR="/prod/OPENFOAM1.7.1/ThirdParty-1.7.1"
declare -x XAUTHLOCALHOSTNAME="pirineus"
declare -x XCURSOR_THEME="DMZ"
declare -x XDG_CONFIG_DIRS="/etc/xdg"
declare -x XDG_DATA_DIRS="/usr/share:/etc/opt/kde3/share:/opt/kde3/share"
declare -x XKEYSYMDB="/usr/share/X11/XKeysymDB"
declare -x XLSF_UIDDIR="/usr/share/lsf/7.0/linux2.6-glibc2.3-x86_64/lib/uid"
declare -x XNLSPATH="/usr/share/X11/nls"
declare -x enf="-n"
declare -x enl=""
declare -x ftp_proxy="http://192.168.255.254:8080"
declare -x http_proxy="http://192.168.255.254:8080"
declare -x https_proxy="http://192.168.255.254:8080"
declare -x no_proxy="localhost, 127.0.0.1"
Matat
ppuigdom@pirineus:/tmp/ppuigdom/snappy24_2/snappy24>
Old   July 11, 2011, 05:10
Bruno Santos
Hi Pere,
Ah HA! Now we are getting somewhere! OK, right on the first command 'mpirun -np 2 bash -c "ls -l"', it doesn't run the second process.
This seems to mean that:
  • either the environment is all set-up manually on your current environment, i.e., you activate parts of the environment manually.
  • or there is something else stopping mpirun.
Are you able to use SGIMPI to run anything else on your machine?
There are three more commands that might be useful for testing:
  • Code:
    `which mpirun` -np 2 `which foamExec` bash -c "ls -l"
  • Code:
    `which mpirun` -np 2 `which foamExec` `which bash` -c "ls -l"
  • Code:
    `which mpirun` -np 2 `which bash` -c "ls -l"
These will help isolate where the problem is. They test if it's a matter of needing full paths to run things or missing environment variables.
There is another thing that you might want to check, although this is for OpenMPI, you'll have to search for the respective option:
Originally Posted by pkr View Post
"Unless otherwise specified, Open MPI will greedily use all TCP networks that it can find and try to connect to all peers upon demand (i.e., Open MPI does not open sockets to all of its MPI peers during MPI_INIT -- see this FAQ entry for more details). Hence, if you want MPI jobs to not use specific TCP networks -- or not use any TCP networks at all -- then you need to tell Open MPI."
When using MPI_reduce, the OpenMPI was trying to establish TCP through a different interface. The problem is solved if the following command is used:
mpirun --mca btl_tcp_if_exclude lo,virbr0 -hostfile machines -np 2 /home/rphull/OpenFOAM/OpenFOAM-1.6/bin/foamExec interFoam -parallel
The above command will restrict MPI to use certain networks (lo, vibro in this case).
Best regards,
Bruno
Last edited by wyldckat; July 11, 2011 at 06:27. Reason: missing spaces on the first two command lines :(
Old   July 11, 2011, 06:13
pere
ppuigdom@pirineus:/tmp/ppuigdom/snappy24_2/snappy24> `which mpirun` -np 2 `which foamExec`bash -c "ls -l"
MPI: pirineus: 0x9d400004db871fb: /bin/sh: /prod/OPENFOAM1.7.1/OpenFOAM-1.7.1-SGI/OpenFOAM-1.7.1/bin/foamExecbash: El fitxer o directori no existeix
MPI: pirineus: 0x9d400004db871fb: /bin/sh: line 0: exec: /prod/OPENFOAM1.7.1/OpenFOAM-1.7.1-SGI/OpenFOAM-1.7.1/bin/foamExecbash: cannot execute: El fitxer o direMPI: pirineus: 0x9d400004db871fb: ctori no existeix
Matat
ppuigdom@pirineus:/tmp/ppuigdom/snappy24_2/snappy24> `which mpirun` -np 2 `which foamExec``which bash` -c "ls -l"
MPI: pirineus: 0x9d400004db871fe: /bin/sh: /prod/OPENFOAM1.7.1/OpenFOAM-1.7.1-SGI/OpenFOAM-1.7.1/bin/foamExec/usr/local/bin/bash: No és un directori
MPI: pirineus: 0x9d400004db871fe: /bin/sh: line 0: exec: /prod/OPENFOAM1.7.1/OpenFOAM-1.7.1-SGI/OpenFOAM-1.7.1/bin/foamExec/usr/local/bin/bash: cannot execute: NMPI: pirineus: 0x9d400004db871fe: o és un directori
Matat
ppuigdom@pirineus:/tmp/ppuigdom/snappy24_2/snappy24> `which mpirun` -np 2 `which bash` -c "ls -l"
total 12
Matat
Old   July 11, 2011, 06:28
Bruno Santos
I'm so sorry, but the online text editor seems to have eaten the spaces between "` `" Either that or I didn't type properly...
Here it is again fixed the first two commands:
  • Code:
  • Code:
