OpenFOAM 2.0.x on Fedora 16 64-bit
Like Tree1Likes
  • 1 Post By JonW
Old   November 22, 2011, 10:31
Default OpenFOAM 2.0.x on Fedora 16 64-bit
Jon Elvar Wallevik
JonW will become famous soon enough
Hi there foamers
just installed OF 2.0.x on Fedora 16 64-bit, without problem:
Here is the procedure (basically the same as for Fedora 14 64-bit):
Note I haven't bothered in compiling paraFoam. Instead I install paraview
and use foamToVTK after each simulation (yum install paraview).
Step 1: (some repetitions here, haven't clean this up, but don't worry)
yum install gcc gcc-c++ binutils-devel flex git-core wget cmake qt4-devel python-devel readline-devel bison
yum install gcc gcc-c++ bison ncurses-devel tix.x86_64 glibc-devel flex zlib-devel libXt-devel
yum install binutils-static python-devel qt-devel cmake flex
Step 2:
cd
mkdir OpenFOAM
cd OpenFOAM/
git clone git://github.com/OpenFOAM/OpenFOAM-2.0.x.git
Step 3:
Download ThirdParty-2.0.1.gtgz from http://www.openfoam.org/git.php
(make sure it is OK with md5sum)
... After successful download, move the file to ~/OpenFOAM
tar xzf ThirdParty-2.0.1.gtgz
mv ThirdParty-2.0.1 ThirdParty-2.0.x
Step 4:
edit your .bashrc file in ~/ and activate openfoam paths by adding (NOTE remember the dot,... that is the "." before !!!)
. $HOME/OpenFOAM/OpenFOAM-2.0.x/etc/bashrc
after the "# User specific aliases and functions" text.
Step 5:
Open new terminal and make sure that your paths are active
type "echo $PATH" and you should see lot of openfoam stuff
Step 6: (this is optional)
export WM_NCOMPPROCS=$(cat /proc/cpuinfo | grep processor | wc -l)
Step 7:
cd $WM_PROJECT_DIR
foamSystemCheck
Step 8:
./Allwmake | tee wmake_log_file_dxxxxxx.txt
Step 9:
mkdir -p $FOAM_SITE_APPBIN
mkdir -p $FOAM_SITE_LIBBIN
foamInstallationTest
Step 10: To check if everything is OK
mkdir -p $FOAM_RUN
cp -r $FOAM_TUTORIALS $FOAM_RUN
cd $FOAM_RUN/tutorials/incompressible/icoFoam/cavity
blockMesh
icoFoam
foamToVTK
paraview & ... and open the file in the ./VTK to see the cfd result
Hope this is of help for the newcomers
Jon
wyldckat likes this.
JonW is offline   Reply With Quote
How to Install OpenFOAM on 64 Ubuntu 9.04 hansel OpenFOAM Installation 62 March 19, 2010 14:43
Openfoam Installtion on Linux Fedora devesh.baghel OpenFOAM 1 November 16, 2009 17:43
OpenFOAM 1.5.x package - CentOS 5.3 x86_64 linnemann OpenFOAM Installation 7 July 30, 2009 03:14
Modified OpenFOAM Forum Structure and New Mailing-List pete Site News & Announcements 0 June 29, 2009 05:56
OpenFOAM Debian packaging current status problems and TODOs oseen OpenFOAM Installation 9 August 26, 2007 13:50
