segment fault during using paraview3120
Old   February 20, 2012, 03:13
Question segment fault during using paraview3120
张德胜
hei@ge is on a distinguished road
Hi,everyone,i installed OpenFOAM2.1.0 and paraview3.12.0,but when i use paraview ,sometimes there occurring segment fault.who can give me some advice to overcome this error.Thanks a lot.
hei@ge is offline   Reply With Quote
Old   February 20, 2012, 04:20
Retired Super Moderator
Bruno Santos
Greetings hei@ge,
Try this:
paraFoam -builtin
I've seen the built-in reader being more stable than the official OpenFOAM reader.
Best regards,
Bruno
Old   February 20, 2012, 04:34
张德胜
Originally Posted by wyldckat View Post
Greetings hei@ge,
Try this:
paraFoam -builtin
Best regards,
Bruno
Hi,first,thank for your replying .I think that paraFoam -builtin is just a way of open case in the root of case.I use paraFoam in the root of case,then i get the fault.
Old   February 20, 2012, 04:38
Bruno Santos
Really? You don't believe me?? Then try this to see if I'm right or not:
paraFoam -help
Old   February 20, 2012, 04:52
张德胜
paraFoam -help
sorry,i did not mean that.i have tryed it .but there are some problem.because my case is not decomposed.How can i use paraFoam -builtin in my case which is not decomposed?Thanks a lot.
Old   February 20, 2012, 08:51
Bruno Santos
Hi hei@ge,
No problem! But I think you aren't seeing very well how the built-in reader works.
The built-in reader can open both kinds of cases, namely decomposed and cases that have not been decomposed!
So I don't understand what kind of problem are you getting... any chance you can post a snapshot of the problem you are getting?
Best regards,
Bruno
Old   February 20, 2012, 20:08
张德胜
I use paraFoam -builtin open my case,and i chose "reconstructed case".Then i get a message: p, li { white-space: pre-wrap; } line 6481
vtkOpenFOAMReaderPrivate (0x9ea1ea0): Error reading line 22 of /root/OpenFOAM/root-2.1.0/run/tutorials/incompressible/simpleFoam/wf2/0/epsilon: Expected number, string or (, found turbulentEpsilon
ERROR: In /home/opencfd/OpenFOAM/ThirdParty-2.1.0/ParaView-3.12.0/VTK/IO/vtkOpenFOAMReader.cxx, line 6481
vtkOpenFOAMReaderPrivate (0x9ea1ea0): Error reading line 21 of /root/OpenFOAM/root-2.1.0/run/tutorials/incompressible/simpleFoam/wf2/0/k: Expected number, string or (, found turbulentKE
vtkOpenFOAMReaderPrivate (0x9ea1ea0): Error reading line 21 of /root/OpenFOAM/root-2.1.0/run/tutorials/incompressible/simpleFoam/wf2/0/p: Expected number, string or (, found pressure.
Can you give me some advice,Thanks very much.
Old   February 21, 2012, 01:53
Sam-CFD's Avatar
Sam Mathew
Sam-CFD is on a distinguished road
Unfortunately, I'm also facing problems with using paraFoam. I had reinstalled OpenFOAM 2.1 and ParaView 3.12 from source build as described on OpenFOAM website.
Especially, when I tried to use Plot over Line, paraFoam is crashing on my Ubuntu 10.04, from CAELinux. The following message gets displayed
X Error: BadRequest (invalid request code or no such operation) 1
Extension: 154 (Uknown extension)
Minor opcode: 182 (Unknown request)
Resource id: 0x3e02d9d
paraview: ../../src/xcb_io.c:183: process_responses: Assertion `!(req && current_request && !(((long) (req->sequence) - (long) (current_request)) <= 0))' failed.
I tried Bruno's proposal to use paraFoam -builtin, but the problem still persists. Any suggestions will be highly valuable.
Thank you.
Sam-CFD is offline   Reply With Quote
Old   February 21, 2012, 02:08
张德胜
The problem is still confusing me .When i solve it ,I will tell you how to do it.
Old   February 21, 2012, 04:42
Bruno Santos
Hi hei@ge and Sam-CFD,
hei@ge: OK, now we are getting somewhere. Your problem is related to a filesystem problem or locale interpretation problem. A few more questions:
  • Do you have OpenOAM installed inside a virtual machine? And if so, is the folder of your case being shared with the real machine?
  • Is your Linux installation done in your native language or in English?
Sam-CFD: The drivers for your machine's graphics card are probably not properly installed.
The other possibility is due to one of several glitches that occurs every once in a while:
Best regards,
Bruno
Old   February 21, 2012, 06:12
Sam-CFD's Avatar
Sam Mathew
Thanks Bruno. The Plot over Line is working for me perfectly.
My problem was fixed after rebooting. It seems after installing the Graphic drivers, I hadn't rebooted my machine yet.
Sam
Old   February 21, 2012, 19:43
张德胜
Thank you,Bruno.I install double system:my host machine is XP,and i install ubuntu10.04 in the F disk. My ubuntu10.04 's language is chinese.In my p case,there is one symbol "$",whether the symbol of $ is too new for reader to recognize it?
Old   February 22, 2012, 03:45
Bruno Santos
Hi hei@ge,
Indeed, it's very possible to be a problem with locale. The usual fix is:
export LC_ALL=C
Before running the applications that need an English locale. But it seems that lately this doesn't always work.
Best regards,
Bruno
Old   February 23, 2012, 20:36
张德胜
Thanks a lot .I think some warnings do not always influent the process of the simulation,right?
Old   February 24, 2012, 03:20
Bruno Santos
Hi hei@ge,
Depends on what the warning message says
Best regards,
Bruno
segment
Segmentation fault when running dieselFoam or dieselEngineFoam in parallel francesco OpenFOAM Bugs 4 May 2, 2017 21:59
Pointwise segment file or .dat file example RuiVO Pointwise & Gridgen 5 November 23, 2015 10:46
Segmentation Fault Shawn_A OpenFOAM Running, Solving & CFD 6 October 31, 2011 14:38
Problem with segment surface and meshing Silmaril ANSYS Meshing & Geometry 1 October 13, 2011 16:42
PHI file structure Eugene Phoenics 9 November 2, 2001 22:00
