January 24, 2014, 10:25 |
Auto block generation?
Daniel WEI (老魏)
Rep Power: 21 |
Dear all,
Does pointwise have an automatic blocking utility that can decompose the domain into blocks (for structured grid generation). I am working on a wall mounted cube mesh (i.e., the flow past a wall mounted cube). Thanks
~ Daniel WEI ------------- Boeing Research & Technology - China Beijing, China |
January 25, 2014, 11:43 |
Chris Sideroff
Rep Power: 22 |
No unfortunately not.
There does however exist a script to convert an H-block into OH blocking. Because H blocks are typically easy to build, it can handy for those specific situations. See the two pictures I made for a pipe. To go from H to OH took literally about 10 sec with the script. You can grab that script (among many others) from Pointwise's github page: https://github.com/pointwise Also, to speed up block assembly once you've created the connectors defining the edges of the block topology, provided the dimensions are correct, one simply needs to select the defining connectors for the block, click Assemble Blocks. Pointwise will create the necessary domains and figure out how to assemble the block. If the dimensions weren't quite right, even though it won't assemble the block it will still assemble as some domains - helpful regardless. Beyond that, I may be able to provide some specific guidance if you post of picture of geometry or configuration. |
January 29, 2014, 13:52 |
Chris Sideroff
Rep Power: 22 |
Daniel,
Here's an excellent video tutorial on multi-block structured meshing Pointwise released today. This demonstrates many helpful tips, including using the scripts I mentioned, for speeding up the structured meshing process. https://www.youtube.com/watch?v=AZTPfd00Oog -Chris |
[blockMesh] Mixer mesh - negative volume problem | jadtwo | OpenFOAM Meshing & Mesh Conversion | 2 | November 6, 2014 16:37 |
foamLog not solving for Ux, Uy, Uz | aerospain | OpenFOAM Post-Processing | 5 | April 18, 2012 10:01 |
[Commercial meshers] Icem Mesh to Foam | jphandrigan | OpenFOAM Meshing & Mesh Conversion | 4 | March 9, 2010 02:58 |
[blockMesh] Tool Block generation with blender | wikstrom | OpenFOAM Meshing & Mesh Conversion | 8 | August 12, 2009 17:09 |
block structured grid generation | Márcio Ricardo Pivello | Main CFD Forum | 6 | February 21, 2002 07:44 |
