how to change the direction of a face in Star-CCM+?
Like Tree1Likes
  • 1 Post By kyle
Old   October 8, 2012, 05:26
Default how to change the direction of a face in Star-CCM+?
senhill is on a distinguished road
In my model, two connected faces have the different direction (one is colored by green, the other is red), I want to offset the two faces together as a whole face, then I need to change the direction of one of the faces. I didn't find the way to do it in the manual. What should I do?
Could anybody help me? Thanks a lot!
senhill is offline   Reply With Quote
Old   October 8, 2012, 10:55
kyle is on a distinguished road
CSET NEWSET CX
CFLIP CSET
CEXT CSET 1 1,,,
Oh wait, wrong software. You will probably have to delete the face and recreate it using the proper click order to get the normals facing the right direction.
husker likes this.
kyle is offline   Reply With Quote
Old   October 8, 2012, 15:12
siara817's Avatar
siamak rahimi ardkapan
siara817 is on a distinguished road
If you have the CAD file, in for example IGES format, open STAT-CCM, click new.
Then open CAD. Import your cad file. if the whole geomtry is as one part, then you need to split it by right clicking on the geometry. Then right click on the specific part and select transfer/ rotate. give the correct angle and rotate it.
siara817 is offline   Reply With Quote
Old   October 9, 2012, 03:02
Thank you very much, but is there any easier way to change the normal directly?
Old   October 10, 2012, 03:28
Krishna
krishnag2002 is on a distinguished road
I think those two elements are in different regions or different parts. Just keep both in the same parts if you dont have any problem to combined both.
Krishna
krishnag2002 is offline   Reply With Quote
Old   October 10, 2012, 03:56
No, they are in the same boudary.
Old   October 10, 2012, 04:19
Krishna
If you can not able to solve this problem, just open this mesh in another mesh software like Icem-CFD or starcd and change the normals will be easy in these software. later you can import again into starccm. I never got a issue with normals in ccm+
Old   October 10, 2012, 04:46
Thank you
I tried to orient the normal in ANSA, but when I import them back to CCM+, the normal turn to be incorrect again. Maybe the CCM+ calculate the normal with its own method again.
P.S. I've found a indirect way to change the normal: select these connected faces together to offset, and then Undo the offset operation, the normal turn to be consistent.
Old   October 10, 2012, 05:04
Krishna
hi
Thank You
You can do swap the edge which is in between. in repair mode shortcut is W letter, just hit W one or 2 times till the color changes.
Krishna
change face direction, star ccm+
how to open star ccm 6.04 version file in older versions pritam.edke Siemens 2 June 25, 2012 03:14
[ICEM] How to change the direction of arrows realstoneman ANSYS Meshing & Geometry 0 May 10, 2012 02:19
CFX or STAR CCM plum1 CFX 3 March 18, 2011 06:33
[Other] StarToFoam error Kart OpenFOAM Meshing & Mesh Conversion 1 February 4, 2010 04:38
