Biased meshing in Star CCM+ (Help needed)
Old   December 7, 2012, 13:40
Default Biased meshing in Star CCM+ (Help needed)
hi
firaga is on a distinguished road
Hello guys, I am a frequent ANSYS-FLUENT user but I have a project I need to do in Star CCM+
I am doing a flow over a flat plate simulation
as you can see, I need a finer mesh along the bottom side, which will be the flat plate for accuracy and efficiency.
This is really easy in Ansys FLUENT, all I have to do is just enable mesh bias.
but there is no bias option in Star CCM+
Is there a way to create this mesh in Star CCM+?
Thank you.
firaga is offline   Reply With Quote
Old   December 7, 2012, 22:52
KHB
lava12005 is on a distinguished road
You can try to use prism layer mesher since it is used for the boundary layer mesh.
You can control the expansion from the wall with this.
lava12005 is offline   Reply With Quote
Old   December 10, 2012, 10:29
dke
dke is on a distinguished road
In this case i recommend the extruder. available in model selection of mesh continuum.
Extrusion type option is located below the Mesh Conditions node of your Boundaries.
Extrusion Parameters option will appear below Mesh Values node.
Once chosen, your are able to define the extrusion length, the amount of layers and the stretching ratio from one layer to the next layer.
dke is offline   Reply With Quote
Old   December 14, 2012, 08:46
Default mESH pROBLEM IN STAR CCM +
jjanak
jjanakpatell is on a distinguished road
hi users,
I have a problem in star ccm+,
when I was start a volume mesh, then i got a message memory access exception.
like,
What should i do for slove this problem?
Thanks and Regards,
JOSEPH
jjanakpatell is offline   Reply With Quote
Old   December 14, 2012, 20:18
abdul099 is on a distinguished road
Although I know it must be pretty hard, would you mind to give a little more information?
Originally Posted by jjanakpatell View Post
hi users,
like,
Attachment 17646
Thanks and Regards,
JOSEPH
We do three types of jobs here:
GOOD, FAST AND CHEAP
You may choose any two!
abdul099 is offline   Reply With Quote
Old   December 17, 2012, 06:33
Default need a suggestion
jjanak
Hello abdul,
thanks for reply.but, thanks god i solved the error of volume mesh problem.
i have some further problem,
my project is related to exhaust gas.
in my project i have to simulate the to a exhaust gas + soot simulation.
so which cfd model suitable related to my project.
DATA:
pIPE INNER DIA - 54MM
OUTER DIA: - 60MM
TEMPRETURE OF EXHAUST GAS : -250 C
EXHAUST FLOW VWLOCITY IS 20 M\S
SO; shall i use a Eulerian multiphase cfd model?
i need ur suggestion.
thanks and regards,
joseph
[Commercial meshers] Using starToFoam clo OpenFOAM Meshing & Mesh Conversion 33 September 26, 2012 04:04
Fluent Vs Star CCM firda Main CFD Forum 3 February 26, 2011 02:51
[Other] StarToFoam error Kart OpenFOAM Meshing & Mesh Conversion 1 February 4, 2010 04:38
error in star ccm maurizio Siemens 3 October 16, 2007 05:17
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues michele OpenFOAM Meshing & Mesh Conversion 2 July 15, 2005 04:15
