Abnomal temperature behavior Star CCM+
Old   November 1, 2020, 04:58
Default Abnomal temperature behavior Star CCM+
Lovepreet Singh
LpSingh is on a distinguished road
Hello everyone,
I have to simulate the cooling of a pipe which is heated on its outer surface by R12. The pipe is heated only in the central part of its length so I have built 3 different pipes and imprinted them together.
The fact is after a certain number of iterations the temperature of the fluid R12 gets below 100 K on a certain number of cells.
I have tried to see how does it work if I heat directly the fluid without the solid pipe and in that case, the simulation goes well but when I add the pipe around the fluid and heat it from outside then this problem occurs.
I have put here also the screenshots of the situation.
Best regards
L. Singh
LpSingh is offline   Reply With Quote
Shadow Wall and temperature norger FLUENT 10 September 28, 2019 11:43
Outlet temperature to temperature boundary condition of velocity inlet. (UDF) dillon Fluent UDF and Scheme Programming 3 March 25, 2018 11:06
Static temperature and Total temperature Jong-Yoon FLUENT 0 September 25, 2016 01:42
How to get free stream temperature in boundary condition saharesobh FLUENT 0 October 9, 2012 17:12
Temperature in vessel during throttling process Astrid Main CFD Forum 2 January 31, 2001 02:34
