Unphysical Solution in a transsonic flow through a nozzle
Old   November 3, 2020, 03:07
Default Unphysical Solution in a transsonic flow through a nozzle
Leonardo
lershbersh is on a distinguished road
Hello everyone,
I am a student from Germany trying to simulate the flowfield inside a spiral Jet Mill using STar CCM+. The problem I face is, that the calculated Gas velocity throug th inlet nozzle is far beyond the sonic speed of ~350 m/s for the given fluid (Nitrogen). I use a mass flow inlet. With the used mass flow I should get around 320 m/s.I use periodic boundarys since the mill has rotation symmetry.
For meshing I use the polyhedral volume mesh, the prism layer mesh and a volumetric mesh control for the nozzle area. I have close to a million cells, wich i thought should suite the purpose well enough. (Some papers used around 300k)
The used solver is the steady state coupled implicit solver with the ausm+ scheme.
The velocity calculation should be limited to the sonic speed for compressible flows. This is written in the Sim Center Documentation.
I would really appreciate some help
Thanks to everyone who takes the time to give me some advice. Best regards
Leo
lershbersh is offline   Reply With Quote
Issues when simulating nozzle flow with outside region blais.bruno SU2 4 March 13, 2024 14:04
UDF for transient pressure inlet, mass flow check at nozzle exit and volumetric heat kokoory FLUENT 0 August 17, 2011 02:07
Compressible de Laval Nozzle Flow rw511 CFX 3 May 22, 2011 19:48
Flow simulation in a Pelton turbine nozzle fivos FLUENT 0 April 19, 2011 11:46
Inviscid Drag at subsonic, subcritical Mach # Axel Rohde Main CFD Forum 1 November 19, 2001 12:19
