Rotating Velocity Inlet BC
Like Tree1Likes
  • 1 Post By fluid23
Old   July 30, 2015, 16:00
Default Rotating Velocity Inlet BC
BlnPhoenix is on a distinguished road
i'm modelling two rotating discs sitting in a water tank. I want to introduce a second phase (air) via this discs. However if i define my discs as air inlet boundaries, tangentional velocity option as in wall boundary is no longer available. Is there a possibility to do rotating velocity inlet boundaries?
thanks for tips!
BlnPhoenix is offline   Reply With Quote
Old   August 17, 2015, 10:17
Matt
fluid23 is on a distinguished road
if you go to physics values under your velocity inlet you can switch the method to be Table XYZ, then load in a table that has the correct velocity components in 3 columns for various points on your inlet. This will require a little math, but is very doable.
BlnPhoenix likes this.
fluid23 is offline   Reply With Quote
Simulation of radial gas turbine, Inlet velocity components dmaz CFX 17 May 19, 2019 09:45
Reduced domain/ Pressure inlet to velocity inlet victoryv FLUENT 1 June 29, 2013 14:45
How to define a fixed velocity for a given mass flow rate on inlet mqasimali FLUENT 2 April 12, 2013 17:24
Variables Definition in CFX Solver 5.6 R P CFX 2 October 26, 2004 02:13
UDF problem : inlet velocity in cyl. coord. system Jongdae Kim FLUENT 0 June 15, 2004 11:21
