November 26, 2010, 13:31 |
Cylinder in 2Dflow
Hi.
I'm needing some help on a case here: i have cylinder in laminar 2D flow, and would like to describe the velosities and the pressure as field functions(at least I think thats the best way), and want to calculate drag and lift. As i start the simulation i got this error: Unable to compute field function Velocity on cells of region "Fluid". please check that function is defined here? and i really dont know what to do with it. Can anyone please help me?? |
November 27, 2010, 21:24 |
Thomas Larsen
Rep Power: 16 |
This is the way I do it.
-Setup a XY plot where the pressure and distance is the function. -Export as a .csv file. -Import in data Analysis program (I use Igor). Run regression analysis. |
benchmark: flow over a circular cylinder | goodegg | Main CFD Forum | 12 | January 22, 2013 11:47 |
Incorrect Drag and Drag Coefficient for flow over a cylinder | ozzythewise | Main CFD Forum | 8 | June 13, 2012 06:24 |
[blockMesh] Specifying boundary faces failes in blockMesh | blaise | OpenFOAM Meshing & Mesh Conversion | 0 | May 10, 2010 03:56 |
rotating cylinder using sliding mesh | Tim Daly | FLUENT | 1 | November 9, 2008 23:02 |
Turbulent steady flow around a circular cylinder | Mirek Kabacinski | FLUENT | 0 | July 23, 2003 18:40 |
