Home > Forums > Software User Forums > Siemens > STAR-CD
Error for inputing mesh file from ICEM CFD to StarCD
Old   August 31, 2009, 06:43
Unhappy Error for inputing mesh file from ICEM CFD to StarCD
ZHOU Sheng
chriszhou is on a distinguished road
Hey, guys
I have a urgent problem. I try to input mesh file from ICEM (11.0) to StarCD(4.06). Exported files from ICEM include .vrt, .inp, .cel. But when I select import Grid (fromat ICEM) in starCD, it shows no cells!! And I can't display geometry or cells.
Did sobody have this problem and solve it already? Thank you so much to tell me how to handle it! Or you can sent me mail for suggestions. chriszsyjy@gmail.com
chriszhou is offline   Reply With Quote
Old   August 31, 2009, 06:56
ZHOU Sheng
Luckly, I found how to do that. You only need to put all the files into default working folder, not your own one. That's OK!
Old   December 4, 2009, 14:48
girl
nottoforget is on a distinguished road
It may sound as a stupid question, but I don't know where is the default working directory. Please tell me how can I find it?
nottoforget is offline   Reply With Quote
Old   December 7, 2009, 06:53
Feng Jiang
kim100 is on a distinguished road
when you run your CD,the default working dictionary will appear like this style :C:/Documents and Settings/Administrator/, and you can also change the button "SET WORKING Dictionary" as you like!
kim100 is offline   Reply With Quote
Old   December 7, 2009, 13:00
girl
Thank you. But I still can't find it because when I launched Starcd I changed the working directory and forgot what was the default one.
Anyway, I'm not realy sure that if I even find the default working directory it will help me to import grids from ICEM to starcd4.08.
Does anybody know how to do it step by step? Or maybe you can check my actions:
1. In Icem - Output - Select solver - output solver - STAR-4, common structural solver - ANSYS.
2. Output - Write input. Then in some folder appears 4 new files, among them there is star.inp
3. In Star-cd - Grids-Import grid- format -ICEM, input file - star.inp - apply.
4. As I understand starcd reads the file star.inp - because it shows the number of cells and other options - BUT - it doesn't show the grid itself in the black window!!
I don't know what to do with it so please write if you have any ideas.
Old   December 7, 2009, 16:28
Joern Beilke
JBeilke is on a distinguished road
simply type the command "ifile star.inp" in prostar
JBeilke is offline   Reply With Quote
Old   December 7, 2009, 23:57
Feng Jiang
You are welcome! I will show you an example path about ICEM+CD,and you can check yourself; the method does not changed; Let me know your mail address I will send you later!
Inter-communicate is a good way to improve study for both of us!
Old   December 8, 2009, 15:05
girl
To beilke: thank you, i tried typing the command but certanly result is the same - all the information about the grid is written, but no graphic view of it((
To kim100:thank you too I've sent you my mail and 'm waiting for a letter now
Old   December 8, 2009, 15:26
Joern Beilke
so what the hell is prostar telling you in the output window? what means "no graphics view..."?
Old   December 9, 2009, 16:34
Smile
girl
I got it now with help of kim100. He sent me a little manual about importing mesh) Thanks!
In fact I understood that the only problem is just me not knowing how to work with starcd and it's everything ok about the mesh.
Old   January 15, 2010, 03:12
Wink
  #11
Wan Mohd Syahid
wmsyahid is on a distinguished road
hi nottoforget,
i also new as CD-adapco user. Previously used MSC program. do you mind if you can help me for some manual you have for this star-cd...
thanks in advance...
wmsyahid is offline   Reply With Quote
[blockMesh] BlockMesh FOAM warning gaottino OpenFOAM Meshing & Mesh Conversion 7 July 19, 2010 14:11
ICEM CFD to CFX geometry and mesh Luca CFX 6 February 4, 2010 16:31
Gambit mesh file import into ICEM CFD dev.... FLUENT 2 January 29, 2009 10:37
ParaView Compilation jakaranda OpenFOAM Installation 3 October 27, 2008 11:46
How to corse mesh in icem cfd? Priety CFX 2 October 2, 2006 03:57
