Home > Forums > Software User Forums > SU2 > SU2 Shape Design
problem about partition setting
Like Tree1Likes
  • 1 Post By zylanboluo
Old   November 6, 2014, 15:13
Default problem about partition setting
Daquan He
YoniHe is on a distinguished road
When I tried to run the tutorial 7 with 4 cores in my computer, there is always an error interrupt the process at the very beginning, with the error information " IOError: [Errno 2] No such file or directory: '/data/hedaquanhe/tutorial7/DESIGNS/DSN_001/DECOMP/mesh_NACA0012_rot_1.su2' "
I went to the directory and found there were 2 files generated, one is "config_PRT.cfg", the other is "mesh_NACA0012_rot.su2", it is different from that filename informed by the error information with " _1" missing.
When I run it on only 1 core of my computer, it can carry out the calculation though I stopped the process after a few iterations.
Can anyone help me to cope with this problem?
YoniHe is offline   Reply With Quote
Old   December 11, 2014, 04:35
Ying Zhuying
zylanboluo is on a distinguished road
I have the same problem when I try running optimization with cores more than 1.
Have you solved the problem?
gina07 likes this.
zylanboluo is offline   Reply With Quote
Old   January 4, 2015, 03:28
Default shape optimization.py error
Zhang Rui
gina07 is on a distinguished road
I met the same problem. Is it that we should modify someplace in some certain script? Hope for your answers~
gina07 is offline   Reply With Quote
Old   January 4, 2015, 03:46
Thomas D. Economon
economon is on a distinguished road
Hi all,
We recently updated the code so that all partitioning is completed internal to SU2_CFD, SU2_DEF, etc. This means that we no longer have SU2_PRT as a separate module that writes additional mesh files with their partition number before the .su2.
Can you please double-check your installation to make sure that you're using the latest and greatest version of SU2? It's SU2 v3.2.7 that has these new features:
https://github.com/su2code/SU2/releases/tag/v3.2.7
You might also download the latest version of the TestCases too (just in case)
https://github.com/su2code/TestCases
Hope this helps,
Thomas D. Economon
SU2 lead developer
economon is offline   Reply With Quote
Problem setting C_MU_T with DEFINE_ADJUST Andy FLUENT 3 June 22, 2018 02:53
Problem setting AV Marko CFX 0 March 18, 2005 08:06
Problem setting C_MU_T with DEFINE_ADJUST sarah_ron FLUENT 1 February 24, 2005 12:11
Help setting up combustor problem Tom FLUENT 0 February 5, 2005 01:20
Warning 097- AB Siemens 6 November 15, 2004 04:41
