[ANSYS Meshing] Dynamic Mesh with Inflation Layer
Like Tree6Likes
Old   June 20, 2013, 05:09
granbycools is on a distinguished road
hey guys, I have a more general question..
I have valves within my flowfield which I want to remove slowly.. my problem is that I donīt understand, how to define the mesh zone (the walls of my valves?) within the fluent mesher so I can select them later as dynamic mesh zones during my fluent simulation. I really appreciate any help, its driving my crazy-.-
granbycools is offline   Reply With Quote
Old   June 20, 2013, 05:25
grayback87 is on a distinguished road
you need to define it in your UDF.
Remember use the same name for your dynamic zone in the UDF and in your case (fluent).
grayback87 is offline   Reply With Quote
Old   September 11, 2013, 18:59
Default Inflation boundary named selection
  #23
Youhanna
Y. E. William is on a distinguished road
Hi every one,
I am trying to give a mesh inflation layer a named selection so i can define it later in dynamic mesh motion.
I hereby appreciate your response.
Y. E. William is offline   Reply With Quote
Old   October 21, 2015, 09:38
Terry
tsaget is on a distinguished road
Originally Posted by Y. E. William View Post
Hi every one,
Hi, I am also interested to know this. I am using inflating and I switched on Smoothing and Remeshing. But somehow as the transient simulation starts, my orthogonal inflation layer gets more and more skewed until I get negative cell error.
I was wondering if I can get the inflation layer to move with my object.
Can anyone help?
tsaget is offline   Reply With Quote
Old   October 23, 2015, 09:37
Far
Sijal
Far has a spectacular aura aboutFar has a spectacular aura about
Send a message via Skype™ to Far
There are two possibilities :
1. choose separate domain for the object + inflation layer. create interface between this domain and outer domain.
In dynamic mesh settings, define both interfaces as rigid body with passitve option. Same goes for the inner side fluid volume.
2. Select those cells (i know how to do it in icem cfd) and defined different volume for that. In dynamic mesh setting put those cells as rigid body , so that they can move with the body.
Far is offline   Reply With Quote
Old   June 30, 2016, 07:09
Anon
superpucc is on a distinguished road
Far, would that also work on a dynamic mesh with a motion UDF for wall movement?
I'm doing VIVs with a motion UDF to induce the oscillating motion due to the fluid force. I've seen users moving the inflation/boundary layer with a rigid body successfully, but they used 6DOF settings, rather than just a motion UDF.
Would just putting the inflation layer (which is already separated from my triangular mesh) as a rigid body work?
superpucc is offline   Reply With Quote
Old   June 30, 2016, 13:12
Far
Sijal
yes. It seems that BL mesh will move as rigid body with body it self. Fluent help also states that.
But how to do that, I cannot recommend any thing at the moment as i haven't tried it.
how to set periodic boundary conditions Ganesh FLUENT 15 November 18, 2020 06:09
[snappyHexMesh] SnappyHexMesh - no layer added bejbro OpenFOAM Meshing & Mesh Conversion 5 February 1, 2020 20:05
3D Hybrid Mesh Errors DarrenC ANSYS Meshing & Geometry 11 August 5, 2013 06:42
[snappyHexMesh] snappy hangs while layer generation bastil OpenFOAM Meshing & Mesh Conversion 3 October 29, 2010 07:19
[snappyHexMesh] Boundary layer generation problems ivan_cozza OpenFOAM Meshing & Mesh Conversion 0 October 6, 2010 13:47
