March 7, 2015, 13:33 |
meshing a turbine rotor in gambit
Rep Power: 11 |
hello,
i'm trying to simulate a wind turbine but when i am creating a volume mesh it leads to an error that says lack of memory,i tried 4 gb and 8gb of ram and it does not use more than half of the ram but i still get the error! anybody could help me?please. |
March 9, 2015, 01:44 |
Maxime Perelli
Rep Power: 41 |
it sounds like you want to mesh your geometry in one shot.
If your geometry is simple, it may be successfull but, if your geometry has some complexity, then you will have hardware problem. Can you display your geometry?
In memory of my friend Hervé: CFD engineer & freerider |
March 12, 2015, 05:34 |
Rep Power: 11 |
dear max,
you are right,i split my geometry and my memory problem is solved but i have negative volume and i think its due to boundary layer mesh,i changed some mesh sizing but i still have negative volumes.can you help me? thank you1.jpg 2.jpg |
March 13, 2015, 01:43 |
Maxime Perelli
Rep Power: 41 |
then try to mesh without BL, and check if you still have this issue, or not.
[GAMBIT] Meshing a wind turbine for wing tip vortexes | Grog106 | ANSYS Meshing & Geometry | 1 | March 29, 2012 06:07 |
Q: how to do a good meshing in turbine usin gambit | oscar | FLOW-3D | 1 | March 14, 2009 23:15 |
problem with gambit unsymmetrical meshing | meenakshi | FLUENT | 1 | March 28, 2008 12:46 |
meshing difficulties in gambit | jyothish | FLUENT | 6 | June 7, 2004 04:13 |
urgent help needed for meshing in GAMBIT | chris | FLUENT | 0 | September 5, 2002 09:18 |
