Ansys 12.1 - Quality mesh -
Old   July 8, 2010, 09:11
Default Ansys 12.1 - Quality mesh -
bob12 is on a distinguished road
hi
i have a 3D case and i have generate the mesh. if i analyze the result of the mesh i look that the quality it isn't the best. how can improve the mesh quality?
now i used a size function: curvature and fine type of mesh; i think the problem is a pipe with a low thikness 0,2 mm so i have used a body size with element size to 0.00065 m. naturally if i used a size more little that now the number are too big.
any suggestions are welcome
thank you
bob12 is offline   Reply With Quote
Old   July 16, 2010, 12:59
Karan Anand
karananand is on a distinguished road
What mesh software are you using? CFX mesher (from Workbench) or ICEM or Gambit?
karananand is offline   Reply With Quote
Old   July 16, 2010, 16:44
Shashank
azurespirit is on a distinguished road
I have a similar issue with a Delta Wing. The enormous aspect ratio is causing problems, I am using ICEM for meshing. Please suggest ways to improve quality.
azurespirit is offline   Reply With Quote
Old   July 17, 2010, 09:32
hi
i use CFX workbench
Old   July 20, 2010, 12:04
Karan Anand
I have not used the workbench for meshing, so i will be of little help. I use ICEM. In there, quality problems are usually solved by changing the surface mesh. Check where the quality of the mesh is bad (usually it is the surface), then select the bad elements and use the edit mesh features to split the elements (volume elements, starting from the surface mesh, i.e. select the surface mesh side and split the volume mesh element touching the surface). Then use smoothing options.
It is always better that you have a coarser mesh. The quality tends to be better than a really fine mesh. So start with coarse mesh, apply smoothing, get quality mesh. Then refine this mesh, apply smoothing. Use splitting option at every step if necessary. usually this helps. Use smoothing with higher number of iterations if you want.
Old   December 11, 2010, 13:04
mrdelaunay is on a distinguished road
why dont you slice your pipe in dm and sweep it? Then utilize a tet/prism for the rest of your model?
mrdelaunay is offline   Reply With Quote
3D Hybrid Mesh Errors DarrenC ANSYS Meshing & Geometry 11 August 5, 2013 06:42
How to export mesh from ANSYS to ANSYS-CFX? Neus CFX 5 September 8, 2010 04:23
Problem importing ANSYS mesh, please help Ankan Kumar FLUENT 1 February 2, 2003 08:38
Importing mesh files from Ansys into Gambit Srinivas FLUENT 2 August 6, 2002 10:02
Gambit Mesh quality TOM FLUENT 1 February 8, 2002 07:00
