Can this warning influence the results?
Old   July 11, 2003, 04:57
Default Can this warning influence the results?
Lee
when I finished running a model (the boundary in inflow region is a stagnation boundary, the boundary in outflow region are several pressure boundary),I found one warning message at the first some iterations: *** WARNING #061 *** RATIO OF STAGNATION PRESSURE AND STATIC PRESSURE AT REGION 1 CELL *** LESS THEN 1. TEMPORARILY SET TO 1.
And when I checked the solution,I doubted the results are correct,but I was not sure that.
So is there anyone who can tell me whether the above warning messages would influence the results?
Thanks a lot for your kind help!
Lee
Old   July 11, 2003, 06:40
Default Re: Can this warning influence the results?
John L
Since this message only appears at the start of your calculation (which is quite normal as the flow inside tries to adjust), it will definitely NOT affect your results.
Gravity (g) Influence on Simulation Results Colin FLUENT 12 September 23, 2015 09:45
Pressure influence Fanny Main CFD Forum 1 January 30, 2009 23:39
influence of yplus Flo Main CFD Forum 5 July 24, 2008 01:31
Influence of Y+ value xiang FLUENT 3 February 6, 2004 19:31
Gravity g's influence on Simulation Results Colin Main CFD Forum 6 November 2, 2003 14:13
