April 10, 2007, 09:49 |
Problem with Convergence at high flow rates
Hi
I am simulating flow through a catalytic converter. ITs a 2-D axisymmetric model. I am having convergence problems when using V2F turbulence model. The problem is the solution converges for low flow rates but doesnt converge at high flow rates say 20 m/s. I have tried using MARS, UD and differencing schems. Can anyone pls help why its not converging at high flow rates. Thank You Regards Saleem |
April 10, 2007, 16:18 |
Re: Problem with Convergence at high flow rates
Are you running a transient or steady state analysis?
How are you defining convergence? Does it diverge? Or does it just not reach a steady value? Have you tried a simpler turbulence model - say standard k-e? |
Display Modes | |
convergence problem with high viscosity | Jan | CFX | 0 | February 29, 2008 05:01 |
Flow rates | Sileno | Phoenics | 9 | June 1, 2006 08:09 |
Flow rates in FLAIR | Sileno | Phoenics | 2 | August 2, 2005 11:43 |
different mass flow rates | michael | FLUENT | 4 | February 21, 2005 04:48 |
Order Criteria and Convergence rates | Erich | FLUENT | 0 | August 12, 2004 13:05 |
