Ansyslmd.exe process goes to 100% using VPN
Like Tree1Likes
  • 1 Post By rrezaei
Old   February 21, 2010, 07:43
Default Ansyslmd.exe process goes to 100% using VPN
LFF
Luis Filipe Fabiani
LFF is on a distinguished road
Hello
I have the Ansys CFX package 12.1 installed on my laptop to view the results, setup cases, etc.
When I connect to our office network through a VPN connection, the ansyslmd.exe process goes to full throttle (50% CPU usage) and stays that way untill I restart the computer.
When I fisically connect to our network (cable), this behavior does not occur, only with VPN connection.
Has anyone noticed something similar?
Thanks
LFF is offline   Reply With Quote
Old   February 21, 2010, 18:02
My guess is the screen display is having problems over the VPN. These can be tricky problems to fix. You will have to do lots of digging to find the answer on that one.
Old   May 24, 2011, 09:49
Arslan
ArslanOZCAN is on a distinguished road
Hi;
I have the same problem. Have you find any solution? Please share...
Best regards...
ArslanOZCAN is offline   Reply With Quote
Old   August 8, 2012, 23:21
reza
rrezaei is on a distinguished road
Dear all,
I had the same problem several month ago but I found a way to solve it.
1-by pressing "ctrl+shift+Esc" window task manager will open
2-click on "performance" tab
3-click on "resource monitor" button then the resource monitor window will open
4-in "overview" tab find "ansyslmd.exe" and check the box on its left
5- then R-click on "ansyslmd.exe" and click on suspend process
note: when you want to use "Ansys" softwer you should do the same but select the "resume process". after each restart or turning off "ansyslmd.exe" will be active again.
Have fun
forouzanmehr likes this.
rrezaei is offline   Reply With Quote
ansyslmd vpn
Error: Fluent process could not be started Clem FLUENT 1 November 26, 2015 13:23
dxFoamExec orphan process bigphil OpenFOAM Post-Processing 0 March 19, 2009 11:08
Fluent coupled with external process Nitesh Goyal FLUENT 0 July 10, 2007 09:35
how to simulate evaporating process of refrigerant chingyou FLUENT 0 October 25, 2005 21:41
controling fluent process Madhukar Rapaka FLUENT 2 October 13, 2005 09:52
