Batch mode question
Old   August 4, 2011, 16:07
Default Batch mode question
Stephen
cfdengineer is on a distinguished road
I have a job running now in batch. What I want to do is make a BC change in the ccl file and then make the batch job update that BC. Can that be done while batch is running? It would be nice if it could without having to write out the result file and then resubmitting the job.
cfdengineer is offline   Reply With Quote
Old   August 4, 2011, 17:02
Edmund Singer P.E.
singer1812 is on a distinguished road
Couple of ways to do this. Alter it using the solver manager "edit run in progress" or use command line "cfx5control"
singer1812 is offline   Reply With Quote
Old   August 4, 2011, 17:10
Stephen
The way I am running it in batch is that I have a folder named for instance folder.dir. I know that you can use the command touch trn and it will write out a backup file and the keep iterating. What I want to do is similar is to make the batch run stop read in the updated ccl or updated def file and then continue iterating. To monitor the batch I do a tail -f then the file.out file. I cannot use solver manager to modify since batch is ruuning a a bunch of linux boxes. I tried to open a batch in progress using the windows based solver manager but it would say that it could not find the .dir folder. I will look into the cfx5control command.
Old   January 16, 2016, 20:05
CTYH's Avatar
CTYH is on a distinguished road
Yes the batch way is helpful ,thank you
CTYH is offline   Reply With Quote
Running Job in Batch mode (EFD) Nick Sessions FloEFD, FloWorks & FloTHERM 0 April 16, 2008 16:44
Prosurf in batch mode Dhruv Siemens 1 September 19, 2005 18:02
how to convert .par to .geomturbo in batch mode xiaoruofu Fidelity CFD 0 December 30, 2004 04:22
batch mode run hennie Siemens 1 October 3, 2002 09:13
Run Fluent in batch mode Shengping LUO FLUENT 2 October 24, 2000 05:42
