Polyline Data Format CFX5
Old   November 28, 2002, 11:12
Default Polyline Data Format CFX5
Claudia
Hi everybody!! I´m trying to create a polyline data format, I just wrote the location of the points (x,y,z) in a txt format , but then in the post (I´m working with CFX-5.5.1) when I call the archive appears the following error message:
ERROR Non ASCII file: 'd:/usuarios/tesis_claudia/Pruebas/Linea4.txt'.
Somebody has an idea of what is happening? Thanks
Old   November 28, 2002, 18:22
Default Re: Polyline Data Format CFX5
Astrid
- Your file has to start with a number that tells CFX-Post how many point are specified in the .txt-file.
- Are you sure it is a txt file? Can you read it with Notepad (in case you use Windows)?
Astrid
Old   November 29, 2002, 07:04
Claudia
Thanks Astrid! I didn't know that the file has to start with the number of points, this must be the problem. I'm sure it is a txt.file, I can read it in my notepad. Thanks a lot
CGNS vs Tecplot Data Format LWhitson2 Main CFD Forum 3 July 1, 2011 13:50
Best format for simulation data? cbisw Main CFD Forum 9 May 30, 2011 02:38
OpenFOAM native format data visualization and workflow zeliboba OpenFOAM Post-Processing 0 September 12, 2008 08:44
XYZ (ASCII format) data points into GAMBIT Neil FLUENT 1 August 7, 2007 09:24
How to update polyPatchbs localPoints liu OpenFOAM Running, Solving & CFD 6 December 30, 2005 17:27
