extract velocity gradients with cfx4.2
Old   November 27, 2002, 04:04
Default extract velocity gradients with cfx4.2
franco belosi
I'd like to extract with usrprt subroutine the velocity gradients. Following the solver manual (pag.221) I set the gradv rouine call allocating also space with setwrk routine. After calling iprec I write the gradients by following the stack instructions of the manual. Apparently the ascii file contains random number (I tried a very simple channel model in order to compute manually the gradients. Doe's anybody coudl give me some help? Thank you. Franco
Old   November 28, 2002, 18:41
Default Re: extract velocity gradients with cfx4.2
Astrid
CFX 4.2? That's old....
Using IPREC, I guess you read all or at least one complete block or am I wrong? Why don't you read your data over a line, e.g., I=1 to N, J=10 and K = 10?
Astrid
Velocity Gradients or Pressure Gradients? owayz OpenFOAM 9 August 14, 2012 13:09
Emergency:UDF for a time dependent parabolic velocity zumaqiong Fluent UDF and Scheme Programming 12 March 25, 2010 12:00
EXtracting Mesh Velocity bornspur CFX 0 February 7, 2009 08:38
Neumann pressure BC and velocity field Antech Main CFD Forum 0 April 25, 2006 02:15
Velocity Gradients at Inviscid Flow Lada FLUENT 0 January 15, 2001 07:20
