mixing 4 kind of fluids
Old   September 18, 2008, 22:57
Default mixing 4 kind of fluids
ranap
hi all, I am a students in mechanical engineering. I want to simulate of mixing 4 kinds of fluids in making lubricant for industry. would you please give me some advise how to simulate that case, i need some tutorial for my final project. thanks.
Old   September 19, 2008, 07:54
Default Re: mixing 4 kind of fluids
sanjay pawar
that will depend on ur geometry and fluid nature.
Old   September 19, 2008, 11:55
CycLone
If the fluids are miscible (i.e. they will mix), you can create a variable composition mixture of the four fluids and specify appropriate mass fractions for each fluid at the corresponding inlets and your initial conditions.
If they are immiscible (i.e. they do not mix, such as water & oil) you can choose them as multiple fluids in a multiphase analysis, specify the free surface option and specify surface tension as necessary.
-CycLone
two mixing compresible fluids solver ziemowitzima OpenFOAM Running, Solving & CFD 27 August 13, 2020 12:40
Mixing of two different fluids in a swirl AK FLUENT 3 July 11, 2007 07:32
mixing of non reacting miscible fluids Himanshu Arora FLUENT 0 June 13, 2005 04:17
FIDAP-Properties Definition in Fluids Mixing Area Q. Hao FLUENT 0 February 17, 2005 12:00
turbulent mixing of two fluids ulrich bieder Main CFD Forum 2 October 9, 1999 16:15
