Butterfly simulation
Old   September 17, 2008, 18:21
Default Butterfly simulation
J.Szary
I'd like to calculate torque for butterfly valve. There is only 3 data known: diameter of pipe, pressure before disc and i know that air is outletting to atmosphere. Is it possible to simulate in CFX? What kind boundary conditions have to set (opening or inlet and outlet)? And the last question: How can i calculate a torque on the shaft? Thank you for your advices. Regards.
Old   September 18, 2008, 19:23
Default Re: Butterfly simulation
Possible - yes.
BCs - upstream probably an inlet with prescribed pressure. Downstream an outlet with zero pressure.
Torque - You can get that from CFX-Post or as a monitor point in the simulation.
Old   September 19, 2008, 17:48
J.Szary
Where exactly should I set BCs into geometry? I put an inlet on entry and outlet at the end of pipe. And solver has crashed. Only openning BC works, but I'am not sure about correctness of this solution.
Why my simulation not agree with the wind tunnel experiment zhaowei CFX 4 July 11, 2015 03:36
Solar Radiation in OpenFOAM plainstyle OpenFOAM Running, Solving & CFD 15 July 8, 2014 04:43
Axial fan simulation in UG/NX 7.5 fan123 Main CFD Forum 2 April 23, 2011 08:22
Simulation of a complex wing in solidworks flow simulation niels1900 FloEFD, FloWorks & FloTHERM 6 April 20, 2011 10:44
strange simulation error Ralf Schmidt FLUENT 2 May 4, 2007 13:02
