December 10, 2008, 09:17 |
CFX mesh
Could anyone advise why it seems impossible to delete some virtual faces in CFX mesh without using "clear virtual topology" option which then means you have to start from scratch? When I select some unwanted individual virtual faces and attempt "delete virtual face" the software goes through the motions of deleting it and advises "operation successful" or words to that affect, but the face is still there, in both the graphic screen and in the model tree on left. The only way of getting rid of it I can find is to clear the whole lot and start again - a bit of a nuisance! Thanks, Ianto |
December 10, 2008, 16:43 |
Re: CFX mesh
This normally works. There may be an issue specific to your model. Have you contacted tech support?
-CycLone |
December 11, 2008, 03:21 |
Re: CFX mesh
Hi CycLone - Thanks for your response.
Okay. I thought it should work, but as a fairly new user wasn't sure if I was missing something. The problem persists with different models. I'll contact support and post their response in case others have the same problem. Regards, Ianto |
[snappyHexMesh] SnappyHexMesh for internal Flow | vishwa | OpenFOAM Meshing & Mesh Conversion | 24 | June 27, 2016 08:54 |
[ICEM] Generating Mesh for STL Car in Windtunnel Simulation | tommymoose | ANSYS Meshing & Geometry | 48 | April 15, 2013 04:24 |
CFX Mesh Deformation problem | Silmaril | CFX | 7 | October 19, 2010 10:00 |
Mesh from ICEM CFD to CFX ! Error ! Why ? Thanks ! | Vu Trinh Tuan | CFX | 11 | March 28, 2005 19:04 |
importing mesh from ICEM CFD into CFX 5 | Jay | CFX | 2 | November 12, 2002 13:46 |
