CFX mesh
Old   December 10, 2008, 09:17
Default CFX mesh
Ianto
Could anyone advise why it seems impossible to delete some virtual faces in CFX mesh without using "clear virtual topology" option which then means you have to start from scratch?
When I select some unwanted individual virtual faces and attempt "delete virtual face" the software goes through the motions of deleting it and advises "operation successful" or words to that affect, but the face is still there, in both the graphic screen and in the model tree on left. The only way of getting rid of it I can find is to clear the whole lot and start again - a bit of a nuisance!
Thanks,
Ianto
Old   December 10, 2008, 16:43
Default Re: CFX mesh
CycLone
This normally works. There may be an issue specific to your model. Have you contacted tech support?
-CycLone
Old   December 11, 2008, 03:21
Ianto
Hi CycLone - Thanks for your response.
Okay. I thought it should work, but as a fairly new user wasn't sure if I was missing something. The problem persists with different models. I'll contact support and post their response in case others have the same problem.
Regards,
Ianto
[snappyHexMesh] SnappyHexMesh for internal Flow vishwa OpenFOAM Meshing & Mesh Conversion 24 June 27, 2016 08:54
CFX Mesh Deformation problem Silmaril CFX 7 October 19, 2010 10:00
Mesh from ICEM CFD to CFX ! Error ! Why ? Thanks ! Vu Trinh Tuan CFX 11 March 28, 2005 19:04
importing mesh from ICEM CFD into CFX 5 Jay CFX 2 November 12, 2002 13:46
