Home > Forums > Software User Forums > FLOW-3D
Mesh resolution to capture thin solid regions
Like Tree1Likes
  • 1 Post By JBurnham
Old   December 19, 2013, 00:38
Default Mesh resolution to capture thin solid regions
Akshay Kumar
Akshay is on a distinguished road
Hey Guys
I have a solid region with a small thickness. How do i make sure that the mesh captures these thin regions. Interestingly even when I have a super fine mesh(order of 10 mil), it does not capture these solids. Is there any special way?
Thanks
Akshay is offline   Reply With Quote
Old   December 22, 2013, 01:57
Jeff Burnham
JBurnham is on a distinguished road
There are three ways:
1) make the mesh cells small enough that there are 3 cells across the thinnest region.
2) if the region is too thin for (1), then consider using a baffle (which is 2-D, and lies on the grid lines) instead of a component (which is 3-D, and needs to be resolved by cells). Note that because baffles snap to the nearest gridline, they will make stair-steps if they're angled diagonal to the mesh. Complex baffles can be imported from .stl files in v10.1 and later.
3) if possible, consider making the regions thicker in CAD. For example, extrude topography surfaces downward. Make sure to re-check and fix the .stl file after you export it, like maybe with netfabb Studio.
brucecumt likes this.
JBurnham is offline   Reply With Quote
Old   December 23, 2013, 00:29
Akshay Kumar
Thanks Burnham but....
The baffles option will not work for me because my model is a moving object. And I don't think I can increase the thickness considering my case. So the only option left is to resolve it through a finer mesh.
I've attached an image(notice it has a small thickness). Now how can I setup mesh planes(grid points) for such a geometry so that I can capture the entire model. Is there any quick way for such situations?
Akshay
Old   December 23, 2013, 00:31
Akshay Kumar
MultiBlocks!!?? One block contained in another? Will that work?
Old   December 23, 2013, 12:35
Jeff Burnham
Yes, you can nest finer blocks inside larger blocks. FLOW-3D will change the boundary condition in the nested block to "inter-block" type automatically. However, the nested blocks do not move, so they can't follow the moving object. Good luck.
Old   December 24, 2013, 07:54
Akshay Kumar
I'll let you know what happens. And..
What is the usual cell count for complex meshes/physics used in Flow3D?
Old   December 31, 2013, 11:38
Jeff Burnham
Cell count depends on how much memory you have. In general:
cell counts in the hundreds will run in seconds
cell counts in the thousands will run in minutes
hundreds of thousands of cells run in hours or days
millions of cells take days or weeks to run
Old   November 2, 2016, 01:53
Default about the boundary condition in the nested block
XuYan
jyoen is on a distinguished road
FLOW-3D will change the boundary condition in the nested block to "inter-block" type automatically.So we needn't set the boundary condition of nested block?
jyoen is offline   Reply With Quote
Old   November 2, 2016, 04:54
hanif pourshahbaz
hanif pourshahbaz is on a distinguished road
Hi
it depends on your problem
but in most cases you can simply use symmetry for boundary conditions
Regards
Hanif
hanif pourshahbaz is offline   Reply With Quote
Old   November 2, 2016, 22:52
XuYan
Hi
Yeah, I also think so.
For example, if the inter-block doesn't have superposition boundaries with outer-block , we can just choose the symmetry for inner-block. But if it has, I think maybe the superposition boundary conditions should be the same as the outer-block's. I will do experiments to text and verify it .
Thank you very much. It's important for my research.
Best
Jyoen
Old   November 3, 2016, 06:12
hanif pourshahbaz
Hi
Best
Jyoen
you are exactly right
and we have done this part in our work
you get my point
Regards,
Hanif
Old   November 3, 2016, 09:34
XuYan
Dear Hanif,
It's cool! Thanks for your reply. It helps me save much time to verify it.
Best
Jyoen
Old   November 3, 2016, 10:48
hanif pourshahbaz
Dear Hanif,
Best
Jyoen
your wellcome
Regards,
Hanif
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 06:20
3D Hybrid Mesh Errors DarrenC ANSYS Meshing & Geometry 11 August 5, 2013 06:42
[snappyHexMesh] Layers:problem with curvature giulio.topazio OpenFOAM Meshing & Mesh Conversion 10 August 22, 2012 09:03
erroneous temps in conjugate model? sieginc. STAR-CCM+ 11 July 14, 2012 03:41
[snappyHexMesh] external flow with snappyHexMesh chelvistero OpenFOAM Meshing & Mesh Conversion 11 January 15, 2010 19:43
