Home > Forums > Software User Forums > FLOW-3D
depth of scour
Like Tree2Likes
  • 1 Post By sycst911
  • 1 Post By JBurnham
Old   March 5, 2014, 09:34
Default depth of scour
mohsen
m.poorjafar is on a distinguished road
hi dears, Flow-3D can calculate depth of the scour ? if not, what method use for calculated it ?
m.poorjafar is offline   Reply With Quote
Old   March 11, 2014, 00:42
Sugonghak PC Bang
sycst911 is on a distinguished road
yes. this is the question i want to ask too.
How do we measure the scour depth in flow 3D?
m.poorjafar likes this.
sycst911 is offline   Reply With Quote
Old   March 12, 2014, 21:16
Jeff Burnham
JBurnham is on a distinguished road
FLOW-3D v9.4, 10.0, and 10.1 all include an output for "net change in sediment elevation". The output is + for increase in elevation (deposition) and - for decrease (erosion). It is calculated for every column of cells (every x,y coordinate), so gravity should point toward -z.
JBurnham is offline   Reply With Quote
Old   March 13, 2014, 05:30
mohsen
thanks dear,can I use " packed sediment height" for calculate height of sediment ?or i "shoud use net change..." ?
Old   March 13, 2014, 13:14
Jeff Burnham
It depends on if you want to see the surface elevation of the bed, or if you want to see the change in elevation.
Old   March 13, 2014, 13:55
mohsen
very thanks, i want to calculate the maximum height of scour
sediment scour pyxbird FLOW-3D 27 March 5, 2016 13:38
Sediment Scour Depth and Sediment Hight hossein_sml FLOW-3D 2 December 31, 2015 02:47
Scour around vertical cylinder pyxbird FLOW-3D 5 December 25, 2013 02:28
Where can I see the depth of scour? loghmn FLUENT 0 December 8, 2012 20:18
For help_Research on bridge scour in a stochastic way superhugo Main CFD Forum 0 April 22, 2011 00:00
