October 21, 2013, 04:47 |
DPM Breakup Model
Carlos
Hi everybody!
I am trying to model the transient injection of gas that causes the dispersion of solid particles whose initial velocity is 0 m/s. The gas will lift the solid particles and will reduce its pressure and velocity during the dispersion process. The particles are fragmented dutring the dispersion process. So I included the breakup Wave model. When I don't use the breakup model the convergence is very good, but, if I activate it the calculation diverges after 9 ms. However, it is necessary to include the particles fragmentation in the simulation. This is some information about my simulation: Boundary conditions: Velocity inlet with varying profile and pressure outlet with fixed value Fluent V13 Turbulence model: RANS RSM and LES Iterations/Time step: 40 Particle size: Between 26 and 86 µm (600000 particles aprox with Rosin-Rammler distribution) Number of mesh elements: 483188 Minimum element size: 8.5e-4 m Maximum element size: 3.0e-3 m fluent time step: 1 ms Solid particles time step: 0.01 µs Please, give me your comments and suggestions Carlos |
October 24, 2013, 05:21 |
lucas s
Rep Power: 12 |
Hello Carlos,
Did you try to set a lower Time Steps and a higher number of iterations/time step? Regards lucas |
How to put melting point data of inert particle in DPM model of Fluent | subhankar_bhandari | Fluent UDF and Scheme Programming | 1 | February 5, 2018 07:08 |
Atomization and Breakup model | xck1986 | OpenFOAM | 4 | May 31, 2014 04:43 |
DPM vs Species transport model | osh | FLUENT | 0 | August 19, 2005 22:15 |
missing mass from dpm model | Jan Rusås | FLUENT | 0 | March 23, 2005 18:05 |
DPM model coupled with VOF | Doug | FLUENT | 0 | March 1, 2005 16:37 |
