Home > Forums > Software User Forums > ANSYS > FLUENT > Fluent Multiphase
Fall, impact and flow of a waterdrop
Old   March 31, 2014, 09:10
Question Fall, impact and flow of a waterdrop
Tilman Stoehr is on a distinguished road
I'm trying to model a drop of water surrounded by air, which is falling down on a slope. I am using the VOF-Model and have been successful concerning the part where the drop is falling. My problem is, that the drop shatters into pieces at impact. I have tried a lot to get rid of this problem, but it didn't work out. Does anyone of you have any experience with that sort of problem? I'd be grateful for any help you could give me!
My Simulation is set up as follows:
General:
Solver: Pressure-Based; Time: Transient
Models:
VOF: Expilcit;Implicit Body Force
Viscous:
k-omega; SST
Phases:
Water and Air; Surface Tension 73.5 dyn/cm; Continuum Surface Stress; Wall Adhesion
BC:
Bottom: No Slip; Roughness Hight: 0.001mm; -Constant: 0.5; Contact Angele 75deg
Solution Methode:
Simplec; Skewness Correction: 0; Gradient: Green-Gauss Node Based; Pressure: Presto; Momentum: Second Order Upwind; Volume Fraction: Geo-Reconstruct; Rest: First Order Upwind
Solution Controls:
Run Calculation:
Time Stepping: Variable; Global Courant Number: 0.5
Attached you'll find a few pictures...
Anybody any idea? Thanks in advance.
Tilman
Tilman Stoehr is offline   Reply With Quote
drop, flow, impact, vof
Review: Reversed flow CRT FLUENT 1 May 7, 2018 05:36
outflow boundary condition ravi_adepu FLUENT 11 January 19, 2018 07:13
Simulate object-water impact with NX Flow lunder Main CFD Forum 0 March 7, 2013 17:40
How Other Conditions Impact Mass Flow Rate Outlet andy P. Main CFD Forum 2 February 9, 2007 10:41
CFD Application in hydraulics valve flow Roger Yang Main CFD Forum 11 February 11, 1999 16:53
