March 31, 2014, 09:10 |
Fall, impact and flow of a waterdrop
I'm trying to model a drop of water surrounded by air, which is falling down on a slope. I am using the VOF-Model and have been successful concerning the part where the drop is falling. My problem is, that the drop shatters into pieces at impact. I have tried a lot to get rid of this problem, but it didn't work out. Does anyone of you have any experience with that sort of problem? I'd be grateful for any help you could give me! My Simulation is set up as follows: General: Solver: Pressure-Based; Time: Transient Models: VOF: Expilcit;Implicit Body Force Viscous: k-omega; SST Phases: Water and Air; Surface Tension 73.5 dyn/cm; Continuum Surface Stress; Wall Adhesion BC: Bottom: No Slip; Roughness Hight: 0.001mm; -Constant: 0.5; Contact Angele 75deg Solution Methode: Simplec; Skewness Correction: 0; Gradient: Green-Gauss Node Based; Pressure: Presto; Momentum: Second Order Upwind; Volume Fraction: Geo-Reconstruct; Rest: First Order Upwind Solution Controls: Default Run Calculation: Time Stepping: Variable; Global Courant Number: 0.5 Attached you'll find a few pictures... Anybody any idea? Thanks in advance. Tilman |
drop, flow, impact, vof |
Review: Reversed flow | CRT | FLUENT | 1 | May 7, 2018 05:36 |
outflow boundary condition | ravi_adepu | FLUENT | 11 | January 19, 2018 07:13 |
Simulate object-water impact with NX Flow | lunder | Main CFD Forum | 0 | March 7, 2013 17:40 |
How Other Conditions Impact Mass Flow Rate Outlet | andy P. | Main CFD Forum | 2 | February 9, 2007 10:41 |
CFD Application in hydraulics valve flow | Roger Yang | Main CFD Forum | 11 | February 11, 1999 16:53 |
