Watertight Geometry Workflow
Old   June 12, 2023, 08:52
Default Watertight Geometry Workflow
abhishek
shingala is on a distinguished road
In the Water tight geometry workflow, I am trying to grow prism layers, here I am using a uniform method. In this method the way the prism layer grow from one layer to another is constant. How can I grow these layers exponentialy instead of constant growth?
(I have seen some seetings to change this but that is available through Outline View Tree> scoped Prism>....) so is that the limitation of watertight geometry workflow? Is it possible to use all advanced and all available features through this watertight geometry workflow?
shingala is offline   Reply With Quote
fluent - parallel, mesh 3d
Watertight workflow and geometry description captainpimienta FLUENT 4 March 8, 2021 21:26
[ICEM] Volume Meshing Problem; YOUR GEOMETRY HAS A HOLE mariachi ANSYS Meshing & Geometry 5 May 30, 2018 02:52
Question about Geometry vs. Meshes EphemeralMemory ANSYS Meshing & Geometry 2 December 8, 2016 13:02
Running CFD parallel. There is no geometry file! CrashLaker SU2 6 April 10, 2014 03:08
[CAD formats] translating geometry from Abaqus to OpenFOAM skuznet OpenFOAM Meshing & Mesh Conversion 3 January 10, 2014 13:49
