June 25, 2013, 13:48 |
Cortex Not Available, Fluent Parallel
My environment:
Ansys 14.5 Windows 8 64-bit Intel Core i7-3517U 8 GB RAM I recently changed a UDF for a project and ever since then I have been unable to open up Fluent from Workbench using parallel processing. Fluent begins to open but suddenly closes and gives me the message shown below: "Exception of type 'Ansys.Fluent.Cortex.CortexNotAvailableException' was thrown" I am able to successfully open and run Fluent using serial processing. However, in parallel processing, regardless of the number of processors used, I receive the message above. I've tried renaming the file and restarting Ansys as well as restarting my computer. So far none of that has worked. Only processing in serial has been successful. If you have any information that might help it would be greatly appreciated. Cheers, Dan |
May 26, 2014, 12:58 |
I think you have an Ansys Academic license, so this kind of license does not allow to run UDF's in parallel.
Regards, Ignacio |
cortex, exception, parallel processing |
Parallel running of Fluent | Bhanu Gupta | FLUENT | 3 | April 7, 2011 09:32 |
Parallel Fluent +UDF | Jack Martinez | FLUENT | 0 | June 28, 2007 11:19 |
Fluent Parallel SUPPORT | MOHAMMED TOLBA | FLUENT | 1 | February 20, 2006 01:27 |
Parallel Fluent with Mandrake | Daniel Dotta | FLUENT | 1 | May 19, 2005 15:30 |
error parallel fluent session | Diet | FLUENT | 2 | January 27, 2005 12:31 |
