Error in Parallel Fluent
Old   July 23, 2013, 07:29
Default Error in Parallel Fluent
Phil
randomPhil is on a distinguished road
hi all,
I am trying to run Fluent v14.5 on 16 cores and am having a problem.
Sometimes when I click cancel to interrupt the iterations, it stops as normal then around a second later Fluent disappears without any warning.
When I check the error log file it says:
"Error [node 999999] [time 7/23/13 12:21:41]".
Does anyone have any idea how I can fix this?
Any help would be greatly appreciated.
Phil
randomPhil is offline   Reply With Quote
Old   July 23, 2013, 07:40
Phil
sorry I left out a bit at the end of the error message, the full message should read:
"Error [node 999999] [time 7/23/13 12:21:41] Abnormal Exit!"
any help would be hugely appreciated!!!
Old   October 8, 2013, 22:38
Default the same problem
Eeethon
Eeethon is on a distinguished road
hi,
I countered the same problem ,too.Is there anybody can help me out?Thanks
Eeethon is offline   Reply With Quote
Old   October 22, 2013, 06:47
HHOS is on a distinguished road
Hello!
I see that you opened the thread some months ago. Did you find a solution?? Because I am facing the same problem!!!!!
Thank you!
HHOS is offline   Reply With Quote
Old   October 22, 2013, 08:51
Paritosh Vasava
vasava will become famous soon enough
Although I am not sure but this may have something to do with node-master communication.
I also suggest you try different method for mesh partition for parallel calculations.
vasava is offline   Reply With Quote
Old   October 22, 2013, 08:59
what do you mean with node-master communication??
The problem happens with the version 14.X, when I run the case with Fluent 12.X, there is no problem...
Before closing the window automatically, it shows "[...]fluent14.5.7\cortex\win64\cx1457.exe received fatal signal (ACCESS_VIOLATION)"
I tried to execute just the cx1457.exe, and it says that a dll file is missing, but it is actually there!!!
Any clue??
Thank you!
Old   October 23, 2013, 01:25
Paritosh Vasava
I am not a cluster geek but all I understand is this: if you dont have your MPI set right then there could be issues with communication between nodes.
The 'node 999999' error also has something to do with UDFs. If your UDF is not compiled with right program (32 bit-64 bit) or right way then there could be some issues.
If you using academic license then it also comes with some limitations e.g. no. of node that can be used for parallel process.
Old   July 18, 2014, 02:09
Unhappy
shivakumar is on a distinguished road
I'm also having the same problem.
Any help would be appreciated.
shivakumar is offline   Reply With Quote
Old   July 18, 2014, 05:02
Paritosh Vasava
Whats exactly is the problem with ansys?
Old   July 18, 2014, 06:02
Unhappy
I tried different methods still am getting the same..
How to overcome from "abnormal exit of fluent"??
Old   July 24, 2014, 02:36
Paritosh Vasava
Whats exactly you do during or after which the fluent closes abruptly?
Old   July 24, 2014, 04:36
Unhappy
  #12
I'm thinking that problem may be due to the boundary conditions, even I tried changing the BCs. But still it is getting the same error and disappearing without giving any information. I'm not understanding what to with this..
"Error node [99999] Abnormal Exit"..
Any help would be appreciated...
Thanks,
Shivakumar
Old   November 16, 2014, 22:52
zhouyuancong
Gates Jobs is on a distinguished road
I use ansys15.0 to simulate a transmission,I also encounter the same problem sa yours,have you solved it?
Thank you!
Gates Jobs is offline   Reply With Quote
Old   November 17, 2014, 08:12
Lucky
Try using a different MPI or playing with your MPI settings.
Old   May 3, 2015, 14:02
Exclamation
  #15
I tried everything discussed in this forum still getting the same error [abnormal exit]. I am using another system to run..
Old   May 3, 2015, 18:31
shereez234's Avatar
M Sereez
shereez234 is on a distinguished road
Hello;
I do not know exactly how to solve the problem you are facing: But i will share my experience of parallel fluent -
PBS File looks like:
### PBS ###
#PBS -l nodes=2 : ppn=8 ( Ok there is no space between : and ppn but I had to use it because a weird emoticon << keeps coming up)
#PBS -l walltime=30:00:00
#PBS -j oe
#PBS -o FILE.log
#PBS -V
#PBS -N Jobname
cd $PBS_O_WORKDIR
cd /home/usr [ This is where you are submitting your job from so figure it]
/data1/ansys/v150/fluent/bin/fluent 3ddp -i pressurebased.jou -t16 -g -mpi=openmpi -ssh >> logfile
OK So using these settings you can create the batch file. Now for the journal file make sure you have it saved in unix format: You can definitely create it in windows also, and transfer it to the linux system: Open the file using VIM editor ( that's what I use) and follow these commands:
:w ( write the file once more)
: set ff=unix ( set the file format as unix)
:wq ( write and quit the file)
hope it gets sorted now: if not come back and ask i will try to help
shereez234 is offline   Reply With Quote
Old   May 6, 2015, 06:44
Thanks for the reply.. Nothing worked for me, still the fluent is spitting the same error.
Old   September 1, 2015, 13:27
thomas
thomas. is on a distinguished road
I know this is an old thread, but did you have any luck with this problem?
thomas. is offline   Reply With Quote
Old   September 1, 2015, 16:28
Lucky
This is usually an intermitten problem with parallel FLuent and it's usually a problem with the MPI. Is your problem intermittent or does it always happen? Try using a different MPI or reconfiguring your current MPI.
Old   September 1, 2015, 23:55
hi,
I tried every settings which are discussed in this forum but couldn't solve it.
Finally, I Uninstalled ANSYS 14.0 and installed 15.0 version, the problem disappeared automatically.
Thanks,
shiv
14.5, error, fluent, node], parallel
Parallel running of Fluent Bhanu Gupta FLUENT 3 April 7, 2011 09:32
Parallel Fluent +UDF Jack Martinez FLUENT 0 June 28, 2007 11:19
Fluent Parallel SUPPORT MOHAMMED TOLBA FLUENT 1 February 20, 2006 01:27
Parallel Fluent with Mandrake Daniel Dotta FLUENT 1 May 19, 2005 15:30
error parallel fluent session Diet FLUENT 2 January 27, 2005 12:31
