fundamental question about Lift Report and Integral Pressure
Like Tree1Likes
  • 1 Post By Kokemoor
Old   June 17, 2015, 02:56
Angry fundamental question about Lift Report and Integral Pressure
farzadpourfattah
farzadpourfattah is on a distinguished road
Hello.
I simulate flow around a wing at angle of attack 0 degree and my pressure distributions is valid experiment result. BUT , when I compare lift force (Report>force>(0,1,0) ) with (Report>integral>static Pressure on wing),
I am confused! that why these value is differ together?
please help me.
farzadpourfattah is offline   Reply With Quote
Old   June 17, 2015, 10:41
Andrew Kokemoor
Kokemoor is on a distinguished road
The integral of pressure is a scalar, it has no direction. Integrating across the entire wing will sum together pressure contributions from all surfaces, regardless of direction.
The lift force is the pressure times the dot product of the face area vector and the direction vector you specify; pressure pushing down will cancel out with pressure pushing up, and pressure pushing to the side will not be affect the calculated force.
farzadpourfattah likes this.
Kokemoor is offline   Reply With Quote
Old   June 17, 2015, 13:14
Smile dear Kokemoor
farzadpourfattah
Thanks alot.You elucidate me about this.
I search in all document of Fluent software to find relation of computing lift force but I can't find,Can you guide me?
Old   June 17, 2015, 14:00
Andrew Kokemoor
Check out the Fluent Theory Guide, Section 22.2.1. Computing Forces, Moments, and the Center of Pressure.
pressure difference - which surface integral? Ralf Schmidt FLUENT 9 December 11, 2012 13:25
Text command for report surface integral jbjiang FLUENT 0 November 2, 2011 14:54
question about the volume integral in axisymmetric problem Renold FLUENT 0 December 7, 2009 11:28
monitor surface integral & report surface integral Ning FLUENT 0 March 18, 2007 12:51
