Gambit on windows 2000
Old   October 3, 2001, 02:55
Default Gambit on windows 2000
Constantinos Constantinou
Hellow
I was wondering to ask if anyone has faced a problem with the installation of gambit 1.3 on windows 2000 (service pack 1): The case is. The software run indicates that it cannot find exceed x server even though exceed 6.2 and exceed 3D are both installed in the registry and the path is ok. Is gambit unable to locate exceed on its own or shall i try to run it from somewhere else.
Regards Costas
Old   October 3, 2001, 05:15
Default Re: Gambit on windows 2000
Greg Perkins
It works fine for me.
Have you set your enviornment variables for Fluent before opeing the command prompt to run gambit?
In my case gambit brings up Exceed and then I select a passive mode. You can change this via exceed.
Greg
Old   October 4, 2001, 09:01
khkoo
Hi.
After installation of Gambit1.3, two executive files are made in Flunent.inc folder.
If you click the file(gambit.exe) in FLUENT.INC\gambit1.3\ntx86\ folder, gambit is not work.
Maybe, you can play the gambit using the file(gambit.exe) in FLUENT.INC\ntbin\ntx86\ folder.
Old   October 22, 2001, 07:15
Aaron
I have met the same trouble, although I have set the PATH and run the right gambit.exe. Will anyone tell me the way to solve it?
Old   October 22, 2001, 12:38
hi.
I sorted out the problem by installing service pack 2. Then you need to install atleast exceed version 6.1 for nt. Try to run the exe from c/fluent/ntbin/nt86. because there is anotherone created at c/fluent/gambit1.3/ntbin/nt86.
Old   October 23, 2001, 03:21
Aaron
I have done all the things you metioned. But, there is the same error. Can you give me some suggestion?
Fluent and Gambit on Windows 7? gholamghar FLUENT 12 July 10, 2012 10:42
Fluent 6.2 & Gambit on Windows XP x64 AcoidanBM FLUENT 9 October 30, 2011 14:08
CFX11 + Fortran compiler ? Mohan CFX 20 March 30, 2011 18:56
Gambit on Windows 98 or 2000 !!! LOTFI FLUENT 5 February 15, 2004 13:05
