gas turbine combustor linear cooling holes- cfd
Old   December 11, 2002, 05:12
Default gas turbine combustor linear cooling holes- cfd
P.K.UDAYAKUMAR
how to numerical model the Gas tubine Combustor liner cooling holes. The Combustor CAN has got 10 linears, each linear has got set of cooling holes(dia 0.05 to 0.1 inch dia) i.e 70 approximately around the circumference.When we create air solid(fluid domain), we will having small cylindrical fluid passages 70 around each linear, which is very tedious to create and to meshing also.
So we want to define some equivalent surface area faces for these cooling holes. How to do it Fluent and what type of Boundary Condition we have to define.
Old   December 13, 2002, 02:08
Default Re: gas turbine combustor linear cooling holes- cf
Atul T. Shinde
It's quite interesting question. We are thinking on the same. Can it be managed with 70 or 140 hole. We have to go for some heat transfer calculation to make sure that the same cooling effect is achieved as is earlier.
[Other] Design gas turbine blades with film cooling and cooling Impingement in Ansys 12.0 pedrin84 ANSYS Meshing & Geometry 7 February 2, 2013 11:52
CFD in turbine Den Main CFD Forum 10 May 7, 2012 01:25
CFD of gas Turbine blade Ali Raza Abid Main CFD Forum 9 February 18, 2012 05:04
modeling cooling holes in turbine blades rajesh kumar gupta Main CFD Forum 1 September 9, 2010 12:13
Design gas turbine blades with film cooling and cooling Impingement in Ansys 12.0 pedrin84 ANSYS Meshing & Geometry 0 August 25, 2010 12:19
