Pipe flow
Old   March 19, 2004, 04:47
Default Pipe flow
Sohail Ahmed
I am doing an internal flow problem through a pipe. I need to know what boundary conditions I have to provide at the inlet / outlet. PLease advise. lots of thanks to every message sender!
Old   March 19, 2004, 06:01
Default Re: Pipe flow
ztdep
velocity inlet on the inlet of the pipe
outflow or pressureoutlet on the outlet of the pipe
Old   March 19, 2004, 07:47
ap
If you model a compressible flow in your pipe, use Pressure Inlet.
Hi
ap
Old   March 20, 2004, 04:12
Sohail Ahmed
Shall I use only pressure inlet or velocity inlet, and not the both. The known values for me are ; pressure inlet, velocity inlet & temperature inlet. At outlet, I know the back pressure, that is, pressure outside the pipe. Please elaborate briefly. Thanks!
Old   March 20, 2004, 05:32
ap
You can't use both boundary conditions if you don't want to implement them using a user defined function.
Choose the boundary condition on the basis of the flow you have.
If you have a compressible flow, like a gas, use a pressure inlet, else, if you have an uncompressible flow, like water, you should use a velocity inlet.
Hope this helps.
Hi
ap
LES transitional pipe entrance flow hasanduz Main CFD Forum 2 October 11, 2013 17:59
HTC in Pipe flow subsemitonium CFX 6 May 6, 2013 22:00
[GAMBIT] meshing in GAMBIT, a flow through a pipe having complex inflow geometry mazhar1613 ANSYS Meshing & Geometry 1 January 11, 2012 23:18
[ASK] Flow in Corrugated Pipe with FLUENT Primadhani FLUENT 1 May 11, 2011 20:41
Pipe Flow Saima CFX 1 January 10, 2011 16:41
