First order upwind
Old   June 12, 2004, 09:16
Default First order upwind
leung
I want to know is it true that a second order upwind always provide a better accuracy than a first order one in all flow problem ?
Thank .
Old   June 12, 2004, 12:57
Default Re: First order upwind
Jonas Larsson
Yea it should do, at least as long as you get the second order upwind scheme to converge. The first order upwind scheme in fluent is very diffusive and it will quickly smear out all your shear layers etc.
Old   June 13, 2004, 08:09
ap
A higher order scheme is more accurate than a lower order one.
The problem is in the stability of the solution and the speed of convergence, which usually becomes lower as you increase the order of the scheme.
Hi
ap
2nd order upwind vs 2nd order upwind!!! Far Main CFD Forum 7 March 14, 2013 12:29
Second order upwind is not UPwind!!! Far CFX 9 May 31, 2011 08:21
2nd order upwind scheme (Fluent and CFX) Far FLUENT 0 May 22, 2011 01:50
Changing LimitedLinear to blend with 2nd order upwind instead of 1st order upwind stevenvanharen OpenFOAM Programming & Development 0 April 11, 2011 05:54
second order upwind cause divege !! khsiavash Main CFD Forum 0 August 4, 2009 15:00
