UDF problem caused by various version of Fluent
Like Tree1Likes
  • 1 Post By Yurong
Old   January 13, 2006, 06:24
Default UDF problem caused by various version of Fluent
Yurong
I come across a problem which maybe caused by various version of FLuent. The former udf was used in Fluent 6.1. When I use these udf in Fluent 6.2, error information appears as followed "Error: FLUENT received fatal signal (ACCESS_VIOLATION) 1. Note exact events leading to error. 2. Save case/data under new name. 3. Exit program and restart to continue. 4. Report error to your distributor. Error Object: ()" I can interpreted these udf but cannot use them just due to these error. Could you please tell me what is the possible reasons for this? Thanks in advance.
Yurong
hady likes this.
Old   January 13, 2006, 09:55
Default Re: UDF problem caused by various version of Fluen
haitao_zhang
i also meet this question. it is caused by any UDF error. you should look carefully over your UDF codes. bear in mind: carefully!!
Old   January 13, 2006, 11:55
Allan Walsh
I have had similar problems. My Fluent support engineer was able to trace one instance back to reading saved boundary conditions in over a new geometry - and apparent differences in V6.1 and V6.2. I still have a problem doing pathlines in 6.2, when the same UDFs were fine in 6.1. No answer for this one.
I don't necessarily think it is a problem with my UDFs - only that 6.1 and 6.2 treat them with subtle differences.
More specifically, what problems are you having?
Old   January 15, 2006, 10:57
Yurong
Thank you all for your attention for my question.
Thanks haitao_zhang for your suggestion and I will check my udf codes carefully.
Allan, my udf is for porosity distribution, inertical resistance factor and viscous resistance factor in porous media.
I haven't solved this problem. I want to cry~
ATTN ALL: SOLUTON TO UDF COMPILE PROBLEM Rizwan Fluent UDF and Scheme Programming 40 March 18, 2018 06:05
OpenFOAM-1.6 install cookbook MadsR OpenFOAM Installation 372 November 20, 2010 11:57
what's the problem with my udf zzyan FLUENT 0 November 4, 2010 03:56
UDF using problem, error happens-heip!! Michael FLUENT 1 December 9, 2008 07:51
Fluent New Version 6.3 Problem Help!!!! phinix FLUENT 1 March 15, 2007 20:16
