May 26, 2008, 09:44 |
Dynamic meshing-In-cylinder model
Hi, I am trying to simulate a piston with the in-cylinder model, but after i load the mesh in fluent it is not available this option, I cannot select it. ¿What could be the problem?.. Thanks.
May 26, 2008, 23:12 |
Re: Dynamic meshing-In-cylinder model
Hi Friend,
I too have faced same kind of problem some times..... For that i have started my analysis from first calling the mesh file then enble the energy equation first then the dynamic mesh option will be highlighted..... With regards, Raghu |
May 28, 2008, 08:15 |
If you want to use the in-cylinder model, you must first switch the solver to unsteady.
Renzo |
dynamic mesh prob inside the cylinder | kantharao | FLUENT | 0 | May 30, 2008 06:36 |
No-constant dynamic layer in-cylinder | Mary | FLUENT | 1 | May 29, 2008 15:02 |
Dynamic Mesh - Ball in Cylinder | Hamish | FLUENT | 5 | October 26, 2007 08:43 |
Dynamic Mesh in an In-cylinder case | venkitaraman | FLUENT | 0 | March 26, 2007 17:15 |
dynamic mesh for oscillating cylinder | gaetan | FLUENT | 0 | October 20, 2006 11:47 |
