February 11, 2009, 07:19 |
problem meshing with low y+
Hello all, I hope someone of you can help me with this problem, I really don't know wath else I can do.
I have to mesh an area around an airfoil but the first points of the boundary layer must be really close to the airfoil I solved the problem of the negative volumes that Gambit usually creates when the distances between the vertices are so small, creaing a large number of areas to be mesh around the airfoil. Now the problem is the zones handedness. Typing /grid/modify-zones/repair-face-handedness I solve the problem but the .cas that I write is not readble again in fluent because f the error: Cell Centroid is xc -0.041689 yc 1.003255 WARNING: no face with given nodes. Thread 11, cell 24868 Error: Build_Grid: grid error. The mesh is the result of a tmerge, it will be a moving mesh. Please help me if yo can. Thank you in advance |
Meshing problem | Tomas | FLUENT | 0 | July 1, 2008 09:31 |
Meshing problem | Sanjay Jain | FLUENT | 2 | April 7, 2008 10:37 |
Meshing problem | Sanjay Jain | FLUENT | 6 | April 5, 2008 09:51 |
meshing problem | danard | CFX | 3 | March 2, 2003 19:17 |
Meshing problem | John | FLUENT | 2 | January 31, 2003 12:08 |
