Parallel communication problem, port 8676
Old   September 4, 2009, 06:00
Wink Parallel communication problem, port 8676
Jordi
jreig is on a distinguished road
hi everyone,
I'm trying to connect 2 pcs in order to launch parallel fluent. I am having problems in only one direction, I mean, if I use "pc1" as the host and "pc2" as the node 1, everything works fine; but if I turn the other way around, using "pc2" as the host I get the next error:
abort: Unable to connect to 'pc1:8676',
sock error: generic socket failure, error stack:
MPIDU_Sock_post_connect(1200): unable to connect to pc1 on port 8676, exhausted all endpoints (errno -1)
MPIDU_Sock_post_connect(1247): unable to connect to pc1 on port 8676, No se ha podido establecer conexión ya que el equipo de destino ha denegado activamente dicha conexión. (errno 10061)
I've already tried to turn the firewall off, and to open this port, but it still doesn't work.
I am using MPICH as the network communicator.
the thing is that I don't wanna use any of these computers in my final parallel calculation, but I have the same problem when using the computers that I will use for the real calculation, and in this case, in both directions.
please help me!!
thanks in advanced
jreig is offline   Reply With Quote
Old   May 25, 2010, 18:20
VK
vincentk is on a distinguished road
Actually I'm tying to do the same and always blocking on this problem (port 8676).
Can you explain how you did for the case that is working?
I mean, how do you run fluent ? "C:/.... 3d -t2 -cnf=.... -path\\ etc...
What does you hosts.txt file look like?
Mine is like this:
192.X.X.1
192.X.X.2
for my both computers
Fluent.inc is shared on both PC.
I do activate port 8676 on my router and no firewall on both PC
Did I miss something, or did something wrong?
Thanks for your help. I'm currently still searching for solution, if I find out, I will let you know. Since then, good night.
vincentk is offline   Reply With Quote
Old   May 27, 2010, 20:30
Jordi
Hi vincentk,
I am sorry but I left the company where I was working on this issue and it was never solved as far as I know. So I can't really help you.
Anyway, if you find the solution, please let me know cause it may be useful in the future.
Old   May 28, 2010, 02:24
VK
Thank you for your answer.
After fiew days since I left this message, I think that the problem solution seems to be in the setting up of the MPICH2 software. This one, is actually, as far as I know, establishing the communication network among processors.
Best regards,
Vincent
parallel, port 8676
RSH problem for parallel running in CFX Nicola CFX 5 June 18, 2012 18:31
Fluent parallel license problem brothershuai Main CFD Forum 0 July 1, 2009 15:41
star cd 4.06 parallel problem whitemelon Siemens 3 October 23, 2008 14:42
Problem in Parallel UDF Giacomo de Renzi FLUENT 12 June 18, 2008 12:19
PROBLEM IN PARALLEL PROGRAMMING WITH MPI Niavarani Main CFD Forum 1 April 20, 2004 06:51
