How to give different flow velocity to air and methane at the same inlet?? |
February 7, 2011, 10:36 |
ravi teja
Hi
I am trying to simulate combustion in a multiple slot burner used in an idealized household boiler Inlet velocities of fuel slot of methane and primary air are given as 1.013m3/hr and 11.57m3/hr respectively. I am at a loss as to how to give 2 inlet velocities at the same boundary condn(mass_flow_inlet). Plz Help~~ |
February 7, 2011, 19:13 |
Real Name :)
It looks like you're trying to specify the inlet based upon volume fractions. If that's the case, what you want to do is change volume fractions to a mass fraction, specify the inlet velocity such that it gives you the appropriate in situ volumetric flow rate, then voila!
If you're unsure how to do this, let us know. Those two gases behave pretty ideally, so this isn't a tough problem to set up by mass. ComputerGuy |
February 16, 2011, 08:50 |
#3 | |
ravi teja
The case that i am trying to run is from an article called "Sensitivity of temperature and concentration measurements in hot gases from FTIR emission spectroscopy" In the article the flow rates of methane, primary air( methane +air), and secondary air are given as 1.013m3/hr, 11.57m3/hr and 1.93m3/hr respectively I took your advice and found out the mass fractions and specified the corresponding inlet velocity for primary air(7.67m/sec) and secondary air(0.178m/sec) by dividing the volumetric flow rate by the area of cross section. I am running the simulation in 2D Unfortunately with the above inlet velocities i am getting an absurd result. I am at a loss in understanding where i am going wrong.Please help me. Last edited by dharanishb; February 17, 2011 at 06:41. |
June 13, 2011, 14:52 |
Ahmed khamis
Mixing AIR and METHANE | zalho | FLUENT | 5 | February 14, 2013 21:52 |
modelling of flow between methane and air | satya | FLUENT | 5 | April 3, 2009 06:32 |
Lean swirled premixed combustion methane air | bisounours | FLUENT | 0 | July 4, 2007 06:52 |
kinetic data for methane air global reaction | James | FLUENT | 0 | March 11, 2006 15:33 |
Combustion Convergence problems | Art Stretton | Phoenics | 5 | April 2, 2002 05:59 |
