Dynamic mesh for tetrahydral elements
Old   June 13, 2011, 11:16
Default Dynamic mesh for tetrahydral elements
faisal mahmood is on a distinguished road
Hi
I am trying to simulate a case of withdrawing reservoir fluid through a plunger. I am trying to apply moving mesh at the plunger head that is moving away at constant velocity (UDF). Tetahydral mesh is utilized. I declard the outlet bounday as wall and used dynamic mesh there. The method I tried is 'Layering' as well as 'remeshing'. But, my elements at the layer attached to the moving boundary get elnogated in transient analysis. Thus aspect ratio goes on increasing too high that the solution diverges at the moving bounday. What options/sizing function shall I apply. Any tutorial on this topic. urgent hepl is required.
faisal mahmood is offline   Reply With Quote
[ICEM] Negative volume error in hybrid mesh siw ANSYS Meshing & Geometry 4 September 3, 2014 05:25
Dynamic mesh update problem. David FLUENT 3 March 15, 2012 05:02
[Gmsh] 2D Mesh Generation Tutorial for GMSH aeroslacker OpenFOAM Meshing & Mesh Conversion 12 January 19, 2012 03:52
[mesh manipulation] Dynamic Mesh Diffusivity Problem dancfd OpenFOAM Meshing & Mesh Conversion 0 August 29, 2010 11:50
Some questions about mesh updating in dynamic mesh technique lzgwhy Main CFD Forum 0 June 14, 2009 08:01
