Parallel Fluent
Old   September 15, 2011, 05:37
Default Parallel Fluent
Irshad
Irshad22 is on a distinguished road
I have 32 GB ram, Intel Xeon processor X5660, 2.80 GHz, 12 MB cache, 1333 MHz memory, Six-Core (two processors) and win7 . But I couldn't run fluent in parallel (local Machine) with x processes. Please help me how to run it?
Irshad22 is offline   Reply With Quote
Old   September 16, 2011, 03:07
Nikolopoulos Aristeidis
Nikolopoulos is on a distinguished road
What operating system you use?
Please give more info (who do you open fluent and what the error message is)
Nikolopoulos is offline   Reply With Quote
Old   September 16, 2011, 05:41
Irshad
Windows 7. There is no error but it is not getting ready to use even I left it for more than 2hrs.
Host is swapping node 0 on machine "<computer name>" (win64)
You can press CTRL+c to stop the startup process!
After this message nothing will appear on message.
Old   September 16, 2011, 09:11
in the fluent launcher what settings do you have under "parallel settings"?
Old   September 16, 2011, 10:40
Irshad
Under Parallel settings.....Number of processes: 4
Interconnects: default
MPI type: default
Run Types: shared memory on local machine
Old   September 18, 2011, 15:38
Mohammad
m2montazari is on a distinguished road
hi,
ensure that you had installed mpi correctly and the paths are set correctly too. then if it dosnt spawn, check that any firewall on your computer is disabled(I think this is your problem). if this dosnt help too, try net interconnection instead of default one. tell me about the results.
yours,
mohammad
m2montazari is offline   Reply With Quote
Old   September 19, 2011, 03:02
in the dropdown list in the mpi try not to use the default setting and post the results
Old   September 28, 2011, 06:08
Vincent Meertens
vmeertens is on a distinguished road
Send a message via MSN to vmeertens
I have tried to open a parallel version of fluent (local Machine). When I want to start fluent I got following error:
Loading "\VMEERTENS-PC\C$\PROGRA~1\ANSYSI~1\v120\fluent\fluent12.0.16\ lib\fl114-64.dmp"
Done
Welcome to ANSYS FLUENT 12.0.16
Copyright 2009 ANSYS Inc.
All Rights Reserved. Unauthorized use, distribution or duplication
is prohibited. ANSYS and FLUENT are trademarks or registered trademarks
of ANSYS, Inc. or its subsidiaries in the United States or other countries.
Loading "\\VMEERTENS-PC\C$\PROGRA~1\ANSYSI~1\v120\fluent\fluent12.0.16\ lib\flprim1119-64.dmp"
Done.
CX_Client_Register (rpc connect): No such file or directory
Error: There is no active application.
Error Object: (grid-valid?)
version>
Interrupting...
Done.
I tried the other settings under “parallel settings” but I still got the same error message.
I didn’t install any MPI software because I thought it is already integrated in W7.
Maybe this has something to do with the Fluent prerequisites I installed the first time? If I remember it well, Fluent installed the C++ 2005 version and asked for a change in the control panel for a SP.
If anyone has an idea for successful parallel settings, please let me know.
Sincerely
vmeertens is offline   Reply With Quote
Parallel running of Fluent Bhanu Gupta FLUENT 3 April 7, 2011 09:32
Parallel Fluent +UDF Jack Martinez FLUENT 0 June 28, 2007 11:19
Fluent Parallel SUPPORT MOHAMMED TOLBA FLUENT 1 February 20, 2006 01:27
Parallel Fluent with Mandrake Daniel Dotta FLUENT 1 May 19, 2005 15:30
error parallel fluent session Diet FLUENT 2 January 27, 2005 12:31
