2d upwind
Old   October 20, 2006, 11:56
Default 2d upwind
Tiz
Is it possible to do a simple 2d code with upwinding for the convective fluxes? Everything seem to work fine in 1D, but adding the second dimension is quite a mess ...
Old   October 22, 2006, 02:37
Default Re: 2d upwind
the rock
yes it is possible...its done all the time. its even a bigger mess when u go 4 3D...
Old   October 22, 2006, 04:08
Tiz
The fact is that while in 1d the flux splitting is quite straightforward, in 2d it not so ... especially when the flow is aligned in one grid direction (roughly). Any practical suggestions?
Old   October 23, 2006, 01:23
the rock
What I am guessing is your scheme is upwind when the mach number is greater then 1, right ?
So I guess the problem you are facing is that when you have 2D, the flow along x direction maybe supersonic and along y its subsonic or vice versa....
So based on my above assumptions on what the problem is, this is my suggestion. If you are traversing along x directions or I lines, check if the dot product of the velocity vector and normal to the edge (along J line or y dir) has magnitude greater then a (speed of sound), and use upwinding accordingly. Same thing holds when traversing along y direction.
I hope this is what you wanted to know, otherwise post more details about the method you are using, like FD or FV, and the scheme etc.
2nd order upwind vs 2nd order upwind!!! Far Main CFD Forum 7 March 14, 2013 12:29
Why results differs between upwind and vanLeerV kjetil OpenFOAM Running, Solving & CFD 1 November 10, 2012 04:55
Second order upwind is not UPwind!!! Far CFX 9 May 31, 2011 08:21
2nd order upwind scheme (Fluent and CFX) Far FLUENT 0 May 22, 2011 01:50
Roe upwind fluxes!! Magesh Main CFD Forum 2 July 17, 2003 11:35
