November 19, 2007, 15:17 |
Lax wendroff and Maccormack
Hi, I tried solving linear advection equation using lax wendroff and maccormack schemes. the initial condition was a step. In the solution I could see numerical oscillations only on the left side of the step. There was no dispersion on the right side of the step. (the wave speed is positive constant for my problem). What could be the reason for this?
thanking you prapanj |
November 20, 2007, 05:02 |
Re: Lax wendroff and Maccormack
Hi
These oscillation are typical for method used, therefore only natural, to remedy this problem you need to add an artificial viscosity to damp these oscillations, otherwise you can use a scheme of Roe with a limiter adequate |
November 20, 2007, 05:59 |
Look for definitions of lagging and leading phase error.
November 20, 2007, 13:18 |
hi I was asking the reason for the oscillations occuring only on one side. thank u
Difference between Lax and MacCormack methods on solutions of 1D problem. | AERO | Main CFD Forum | 2 | January 19, 2000 14:36 |
