July 25, 2001, 16:00 |
Quadratic Upwind Interpolation
Hi there,
I am seeking references giving the expression for the coefficients used in the QUICK interpolation scheme for non-orthogonal and non-uniform grids. Thanks in advance, Frederic Felten. |
August 1, 2001, 10:09 |
Re: Quadratic Upwind Interpolation
Hi Frederic,
try the following article: Darwish et al.; Numerical Heat Transfer B; Vol. 26; 1994; pp79-96; Good luck and best regards Romuald |
August 1, 2001, 11:41 |
thanks for the answer, but i actually derived the quadratic interpolation on paper, and it is very easy to figured out the coefficients. I posted the message without trying to do it myself first. I guess i was just lazy.
Thanks anyway, Sincerely, Frederic Felten, |
August 1, 2001, 14:15 |
Frederic,
From you posting here, I got the impression that you are involved in code development for LES and your group is pretty gung-ho about minimizing artificial damping. Why this sudden interest in QUICK which usually leads to some damping. JUst curious. |
August 1, 2001, 20:00 |
Well, that's a good question. Actually we are trying to understand why some people have used the QUICK scheme in collocated curvilinear geometry when others have just used a second order central difference scheme (CDS).
We realized that when the geometry is simple, like a wavy channel, the second order CDS works fine ,and almost no oscillations are present in the field. ( check Armenio and Piomelli, Flow, Turbulence and Combustion, vol 65, pp 51-81, 2000 ) When the geometry becomes a bit more complex, like a polar cavity, or flow in a bended duct (Check Zang et al. , J.Comp. Phys., vol 114, pp 18-33, 1994) a dissipative scheme like QUICK or SHARP is used to smooth out the field and not get just junk from the oscillations. Actually i'm currently finishing the redaction of a paper that will be presented a the 3rd AFOSRThird AFOSR International Conference on Direct Numerical Simulation and Large Eddy Simulation (http://math.uta.edu/~taicdl/) next week. The paper addresses some of these issues and some better ways of getting ride of the oscillations without using QUICK. If you are interested, i'll send you a copy of this article as soon as the conference is over. Sincerely, Frederic Felten. |
2nd order upwind vs 2nd order upwind!!! | Far | Main CFD Forum | 7 | March 14, 2013 12:29 |
Use of upwind scheme for interpolation of u/v | quarkz | Main CFD Forum | 6 | August 30, 2011 04:10 |
Second order upwind is not UPwind!!! | Far | CFX | 9 | May 31, 2011 08:21 |
solution diverges when linear upwind interpolation scheme is used | subash | OpenFOAM | 0 | May 29, 2010 01:23 |
Interpolation scheme for characteristic upwind for compressible flow | enok | OpenFOAM Running, Solving & CFD | 0 | May 8, 2006 14:37 |
