flow resistance of cylinder in parallel flow
Old   May 8, 2009, 16:01
Default flow resistance of cylinder in parallel flow
Ralf Schmidt
Ralf Schmidt is on a distinguished road
Hi!
I am looking for literature data for the flow resistance (and heat transfer) of a number of parallel aligned finite length cylinder in turbulent axial flow.
It is something like a rod bundle. I need the resistance of the inflow (around the top surfaces), the parallel flow and the outflow (around the back surface).
Thank you!!
Ralf
gas flow
V
=>... Length L
=> ________
=> I________I ...... Diameter D
=> ________....... Distance A
=> I________I
=> ________
=> I________I
=> ________
=> I________I
CFD - nothing but Colourful Fluid Dynamics
Ralf Schmidt is offline   Reply With Quote
Old   May 10, 2009, 05:31
Rami Ben-Zvi
Rami is on a distinguished road
Have a look in Zukauskas book "Tube Banks in Crossflow" or in his chapter in "Advances in Heat Transfer" 1987.
Rami is offline   Reply With Quote
Old   May 10, 2009, 12:06
Ralf Schmidt
Hi!
as i understood, this is about cylinder in cross flow.
But i need data for cylinder(s) in axial flow!
Especially for a larger number of them (something like 100-500), aligned axis-parallel, depending on the cylinder diameter, the length and the distance between them.
The data should include the edges of the cylinder...
Thanks..
Ralf
Old   May 11, 2009, 02:26
Rami Ben-Zvi
Sorry, I missed the point that the flow is parallel to the cylinders...
benchmark: flow over a circular cylinder goodegg Main CFD Forum 12 January 22, 2013 11:47
flow around a cylinder pXYZ Main CFD Forum 14 July 25, 2011 10:05
Anybody knows smth abt the flow around a cylinder? Wenxuan Main CFD Forum 3 March 20, 2007 16:19
flow around circular cylinder...plz help yousef FLUENT 4 March 28, 2006 11:01
Inviscid Drag at subsonic, subcritical Mach # Axel Rohde Main CFD Forum 1 November 19, 2001 12:19
