[PyFoam] On Windows: Setup
Like Tree1Likes
  • 1 Post By tmik
Old   August 23, 2018, 07:56
Default On Windows: Setup
Thomas M
tmik is on a distinguished road
Hi all,
I'm trying to get a good setup for monitoring the residuals from my solve using OpenFOAM for Windows.
Typically people use foamMonitor (https://cfd.direct/openfoam/user-gui...hs-monitoring/), gnuplot (Tutorial of how to plot residuals !), or PyFoam (pyFoamPlotWatcher.py; Using pyFoamPlotWatcher.py To Plot Residuals)
However! I can't get any of these to work inside windows.
So far the best I can do is open the residual.dat file in excel and update manually.
Any suggestions on a nicer tool to use? Perhaps a python script for plotting?
-Thomas
tmik is offline   Reply With Quote
Old   August 23, 2018, 15:09
Retired Super Moderator
Bruno Santos
Greetings Thomas and welcome to the forum!
Please provide more details to which "OpenFOAM for Windows" installation instructions you've followed.
I ask this because nowadays there are 2 to 5 different ways to install OpenFOAM on Windows... and each will have a different way to install PyFoam...
Best regards,
Bruno
Old   August 23, 2018, 15:16
Thomas M
Hi Bruno! Thanks!
I'm using OpenFOAM4Windows v1806.0 (using docker), on windows 10.
I've got python 3.7.0 installed via PyCharm IDE with the PyFoam 0.6.10 package.
Update: As a work-around I've gotten excel to do the plotting for me.
I've used the "Get External Data" > "From Text". From here, I've used tab separated text columns, and plotted the columns on a scatter plot.
Seems to work alright for a windows hack!
wyldckat likes this.
Last edited by wyldckat; August 23, 2018 at 15:33. Reason: merged posts that were a few minutes apart
Old   August 23, 2018, 15:40
Bruno Santos
Quick answer: If you still want to use PyFoam for plotting the residuals, then please run the following script and provide its output:
pyFoamVersion.py
It will tell us what features are available and which aren't.
Furthermore, what error messages do you get when you try to run PyFoam's plotting scripts?
Old   January 22, 2021, 05:40
OlivierM is on a distinguished road
hello
I have exactly the same issue: the only way for me to plot residuals is through excel from the dat. files.
I have spent days to try making it with foamMonitor, gnuplot, pyFoam but no success at all !
I have installed PyFoam using pip3
$ pip3 install PyFoam
Requirement already satisfied: PyFoam in ./.local/lib/python3.8/site-packages (2020.5)
Requirement already satisfied: numpy in /usr/lib/python3/dist-packages (from PyFoam) (1.17.4)
and this is what I got when asking for pyFoam version:
$ pyFoamVersion.py
Traceback (most recent call last):
File "/usr/local/bin/pyFoamVersion.py", line 4, in <module>
__import__('pkg_resources').run_script('PyFoam==20 20.5', 'pyFoamVersion.py')
File "/usr/lib/python3/dist-packages/pkg_resources/__init__.py", line 667, in run_script
self.require(requires)[0].run_script(script_name, ns)
File "/usr/lib/python3/dist-packages/pkg_resources/__init__.py", line 1452, in run_script
raise ResolutionError(
pkg_resources.ResolutionError: Script 'scripts/pyFoamVersion.py' not found in metadata at '/home/<USER>/.local/lib/python3.8/site-packages/PyFoam-2020.5.dist-info'
would you have any idea of what could be the problem ?
I am running OFv2012 on Unbuntu 20.04 LTS wl2
many thanks
OlivierM is offline   Reply With Quote
Old   January 24, 2021, 18:14
Assistant Moderator
Bernhard Gschaider
Originally Posted by OlivierM View Post
hello
$ pyFoamVersion.py
many thanks
You already the asked the question in Using pyFoamPlotWatcher.py To Plot Residuals Please don't crosspost
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request
SU2 windows setup options esco_rep SU2 Installation 3 August 20, 2015 19:56
CFX Parallel Setup on windows 7 x64 SlicedBread CFX 1 November 14, 2011 17:06
CFX11 + Fortran compiler ? Mohan CFX 20 March 30, 2011 18:56
setup windows cluster radiatn STAR-CD 2 March 30, 2009 13:52
PVM RSH parallel setup problem Windows XP abe CFX 11 January 30, 2006 05:10
